Eddy viscosity ratio in interDyMFoam?
Old   June 5, 2013, 06:28
Default Eddy viscosity ratio in interDyMFoam?
Pal Schmitt
wavemaster is on a distinguished road
I simulated a case of a floating body in shallow water which unfortunately I cannot share. It compares very well to experimental results and everything seems good, until I look at the turbulence modeling (komegaSST RANS model).
I want to visualize for the eddy viscosity ratio, For water I used nu=1e-6. m^2/s, Vorticity looks like what i expected but nut gives values of up to 0.001m^2/s.
Using the paraview calculator and just dividing nut/nu for the water phase gives very high eddy viscosity ratios...
I cannot find the error and the dimensions seem correct, is it still possible that I need to divide by density? Is there a bug in interFOAM in OF 2.1.x?
Dividing by density of water gives much more reasonable results but I cannot justify it...
Confused....
Cheers,
Pal
wavemaster is offline   Reply With Quote
Old   March 9, 2014, 03:57
esmaeil
agar_shod is on a distinguished road
hi pal
i have the same problem too.
how you solved your problem?
tnx
agar_shod is offline   Reply With Quote
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
Ratio of eddy viscosity to molecular viscosity : Laminar or turbulent flow? JuPa CFX 7 September 9, 2013 07:45
Eddy viscosity ratio to get the boundary layer thickness Cecco CFX 3 May 28, 2013 11:17
Eddy viscosity ratio and LES Lance CFX 13 April 29, 2013 19:02
Question about eddy viscosity ratio limit Piti CFX 2 January 17, 2008 16:49
