June 15, 2019, 15:16 |
Boundary Conditions mismatch for alphat
Raza Javed
Rep Power: 6 |
Hello Everyone,
I am modelling kEpsilon Turbulence model in chtMultiRegionSimpleFoam. I included alphat in my parameters but I don't know, what boundary conditions to use for it. My boundary conditions for other parameters were working fine, but when I included alphat in my system/changeDictionaryDict, I am getting the following error: Code:
--> FOAM FATAL ERROR: cannot be called for a calculatedFvPatchField on patch inlet of field U in file "/home/openfoam/run/final_geometry_turbulent/0/fluid/U" You are probably trying to solve for a field with a default boundary condition. From function Foam::tmp<Foam::Field<Type> > Foam::calculatedFvPatchField<Type>::gradientInternalCoeffs() const [with Type = Foam::Vector<double>] in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 187. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&)*** Reading solid mesh thermophysical properties for region hot2 Adding to thermos Selecting thermodynamics package { type heSolidThermo; mixture pureMixture; transport constIso; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } Adding to radiations Radiation model not active: radiationProperties not found Selecting radiationModel none Adding fvOptions Creating finite volume options from "constant/fvOptions" Selecting finite volume options model type scalarSemiImplicitSource Source: heatSource - selecting all cells - selected 939 cell(s) with volume 1.4e-06 *** Reading solid mesh thermophysical properties for region hot3 Adding to thermos Selecting thermodynamics package { type heSolidThermo; mixture pureMixture; transport constIso; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } Adding to radiations Radiation model not active: radiationProperties not found Selecting radiationModel none Adding fvOptions Creating finite volume options from "constant/fvOptions" Selecting finite volume options model type scalarSemiImplicitSource Source: heatSource - selecting all cells - selected 921 cell(s) with volume 1.4e-06 Time = 0.01 Solving for fluid region fluid at ??:? #1 Foam::error::abort() at ??:? #2 Foam::calculatedFvPatchField<Foam::Vector<double> >::gradientInternalCoeffs() const at ??:? #3 Foam::fv::gaussLaplacianScheme<Foam::Vector<double>, Foam::SymmTensor<double> >::fvmLaplacianUncorrected(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #4 Foam::fv::gaussLaplacianScheme<Foam::Vector<double>, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #5 Foam::fv::laplacianScheme<Foam::Vector<double>, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #6 Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) at ??:? #7 Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #8 Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #9 Foam::linearViscousStress<Foam::RASModel<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > > >::divDevRhoReff(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const at ??:? #10 ? at ??:? #11 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #12 ? at ??:? Aborted (core dumped) Any help would be highly appreciated. Thank you |
alphat, openfoam, thermal diffusivity, turbulence modelling |
Display Modes | |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 09:44 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 10:49 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
