June 19, 2013, 00:13 |
interFoam error with imported Gambit mesh
Yao Lu
Rep Power: 12 |
I am solving the damBreak tutorial in user guide with imported Gambit mesh.
Boundary conditions in boundary file have been rewrited. This is .msh file generated in Gambit. https://skydrive.live.com/?cid=a9e4f...4756B9AE%21105 setFields is ok. 1.jpg Error occurs when I solve the case with interFoam. Code:
luyao@luyao:~/OpenFOAM/luyao-2.2.0/run/case/multiphase-interFoam/1/damBreak2$ interFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0-5be49240882f Exec : interFoam Date : Jun 19 2013 Time : 10:26:21 Host : "luyao" PID : 4020 Case : /home/luyao/OpenFOAM/luyao-2.2.0/run/case/multiphase-interFoam/1/damBreak2 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: Operating solver in PISO mode Reading field p_rgh Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Reading g Calculating field g.h No finite volume options present time step continuity errors : sum local = 0, global = 0, cumulative = 0 DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0, global = 0, cumulative = 0 Courant Number mean: 0 max: 0 Starting time loop Courant Number mean: 0 max: 0 Interface Courant Number mean: 0 max: 0 deltaT = 0.00119048 Time = 0.00119048 MULES: Solving for alpha1 Phase-1 volume fraction = 0.130194 Min(alpha1) = 0 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.130194 Min(alpha1) = 0 Max(alpha1) = 1 DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 0.0365699, No Iterations 3 #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 Uninterpreted: #3 at tensorField.C:0 #4 in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/interFoam" #5 in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/interFoam" #6 in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/interFoam" #7 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #8 in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/interFoam" |
June 19, 2013, 08:08 |
Nicklas Linder
Rep Power: 13 |
Hi!
I have similar problems, but only with a modified interFoam solver so far. Interesting that it also happens with the standard solver. What are your boundary conditions? Greetings |
June 19, 2013, 08:28 |
Nicklas Linder
Rep Power: 13 |
Update:
Can you confirm that commenting out the first two lines here (pEqn.H): Code:
if (pimple.finalNonOrthogonalIter()) { //phi = phiHbyA - p_rghEqn.flux(); //U = HbyA + rAU*fvc::reconstruct((phig - p_rghEqn.flux())/rAUf); U.correctBoundaryConditions(); fvOptions.correct(U); } The reason at this point is, that p_rghEqn.flux() returns a "-nan" field. Your first written timestep should be "-nan" everywhere in p_rgh, correct? BTW: Serial or parallel? greetings Last edited by nlinder; June 19, 2013 at 09:49. |
June 19, 2013, 10:30 |
Nicklas Linder
Rep Power: 13 |
Sorry for answering myself all the time but:
It seems as if Code:
- ghf*fvc::snGrad(rho) Greetings Nicklas |
June 21, 2013, 00:42 |
#5 | |
Yao Lu
Rep Power: 12 |
I am afraid that we got different problems although we received similar error. Mine has been solved, see here. Which line do you want me to comment? Both Code:
phi = phiHbyA - p_rghEqn.flux(); U = HbyA + rAU*fvc::reconstruct((phig - p_rghEqn.flux())/rAUf); Code:
- ghf*fvc::snGrad(rho) |
June 21, 2013, 04:48 |
Nicklas Linder
Rep Power: 13 |
Hi!
Allright, thanks for the information. In my case it was enough to comment out Code:
- ghf*fvc::snGrad(rho) Thanks for discussing Nicklas |
Display Modes | |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Question on InterFoam moving mesh capabilities | ziv | OpenFOAM Running, Solving & CFD | 0 | April 23, 2008 10:11 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
Successive Mesh in Gambit | ashish | FLUENT | 0 | April 28, 2006 01:42 |
How to mesh a circle by Gambit? | Zhengcai Ye | FLUENT | 5 | March 24, 2006 02:04 |
