Potentialfoam requesting surfaceScalarField phi |
November 14, 2013, 16:53 |
David
Rep Power: 13 |
Hi mates,
I am trying to initalize my simplefoam problem with potentialfoam and now i am getting this error: Code:
--> FOAM FATAL ERROR: request for surfaceScalarField phi from objectRegistry region0 failed available objects of type surfaceScalarField are 0 ( ) From function objectRegistry::lookupObject<Type>(const word&) const in file /opt/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 131. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/opt/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 Foam::Ostream& Foam::operator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) in "/opt/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/potentialFoam" #3 Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const& Foam::objectRegistry::lookupObject<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> >(Foam::word const&) const in "/opt/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #4 Foam::surfaceInterpolationScheme<Foam::Vector<double> >::addMeshConstructorToTable<Foam::upwind<Foam::Vector<double> > >::New(Foam::fvMesh const&, Foam::Istream&) in "/opt/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #5 Foam::surfaceInterpolationScheme<Foam::Vector<double> >::New(Foam::fvMesh const&, Foam::Istream&) in "/opt/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/potentialFoam" #6 at potentialFoam.C:0 #7 in "/opt/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/potentialFoam" #8 __libc_start_main in "/lib/libc.so.6" #9 in "/opt/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/potentialFoam" Aborted I post my fvsolution: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.1 | | \\ / A nd | Web: http://www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-06; relTol 0.01; smoother DIC; cacheAgglomeration true; nCellsInCoarsestLevel 500; agglomerator faceAreaPair; mergeLevels 1; } U { solver PBiCG; preconditioner DILU; tolerance 1e-06; relTol 0.0; } k { solver PBiCG; preconditioner DILU; tolerance 1e-06; relTol 0.0; } epsilon { solver PBiCG; preconditioner DILU; tolerance 1e-06; relTol 0.0; } } //version OF 1.7.1: //SIMPLE //{ // nNonOrthogonalCorrectors 6; // convergence 5e-3; //} //version OF 2.1.1: SIMPLE { nNonOrthogonalCorrectors 8; residualControl { p 5e-3; U 1e-3; "(k|epsilon)" 1e-3; } } //version OF 1.7.1: //relaxationFactors //{ // p 0.05; // U 0.05; // k 0.01; // epsilon 0.01; //} //version 2.1.1: relaxationFactors { fields { p 0.3; } equations { U 0.7; k 0.1; epsilon 0.1; } } potentialFlow { nNonOrthogonalCorrectors 10; } // ********************1***************************************************** // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.1 | | \\ / A nd | Web: http://www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; grad(p) Gauss upwind phi; grad(U) Gauss upwind phi; } divSchemes { default Gauss linear; div(phi,U) Gauss upwind; div(phi,k) Gauss upwind;//Gauss vanLeer; div(phi,epsilon) Gauss upwind;//Gauss vanLeer; // version 1.7.1: // div((nuEff*dev(grad(U).T()))) Gauss linear; // version 2.1.1: div((nuEff*dev(T(grad(U))))) Gauss upwind phi; } laplacianSchemes { default Gauss upwind phi corrected; //laplacian(nuEff,U) Gauss linear corrected; //laplacian(1,p) Gauss linear corrected; //laplacian((1|A(U)),p) Gauss linear corrected; //laplacian(DkEff,k) Gauss linear corrected; //laplacian(DepsilonEff,epsilon) Gauss linear corrected; } interpolationSchemes { default upwind phi; interpolate(U) upwind phi; } snGradSchemes { default corrected; } fluxRequired { default no; p; } // ************************************************************************* // |
November 15, 2013, 02:15 |
Bernhard
Rep Power: 21 |
I think you should change this
interpolate(U) upwind phi; Code:
interpolate(U) linear; |
November 15, 2013, 15:57 |
#3 | |
David
Rep Power: 13 |
MSHArequest for surfaceScalarField phi from objectRegistry | msha | OpenFOAM Running, Solving & CFD | 11 | March 21, 2014 03:35 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
Summing phi over all faces in patch | NewtoFOAM | OpenFOAM Programming & Development | 2 | May 8, 2013 05:37 |
Sample phi potentialFoam | doubtsincfd | OpenFOAM | 0 | May 16, 2011 03:26 |
Turbulence Model phi vs phi_ | doug | OpenFOAM Running, Solving & CFD | 4 | November 10, 2009 04:33 |
