low local continuity while high global continuity
Like Tree2Likes
  • 1 Post By wyldckat
Old   June 15, 2013, 10:19
Default low local continuity while high global continuity
immortality's Avatar
Ehsan
immortality is on a distinguished road
what does low local continuity residual(1e-5)but high global(1e-18)mean?
DILUPBiCG:  Solving for Ux, Initial residual = 0.0004256482273, Final residual = 3.42419877e-17, No Iterations 4
DILUPBiCG:  Solving for Uy, Initial residual = 0.0008584110976, Final residual = 1.699508551e-16, No Iterations 4
DILUPBiCG:  Solving for e, Initial residual = 0.0004690168561, Final residual = 4.48278334e-17, No Iterations 4
DILUPBiCG:  Solving for p, Initial residual = 0.0004642938087, Final residual = 8.887120082e-17, No Iterations 4
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
time step continuity errors : sum local = 4.223753118e-06, global = -9.485719823e-18, cumulative = -4.473784803e-05
DILUPBiCG:  Solving for p, Initial residual = 3.306483671e-07, Final residual = 6.449921349e-17, No Iterations 3
time step continuity errors : sum local = 4.21218922e-06, global = -9.149711212e-18, cumulative = -4.473784803e-05
DILUPBiCG:  Solving for omega, Initial residual = 0.0003045968168, Final residual = 4.305610069e-16, No Iterations 4
DILUPBiCG:  Solving for k, Initial residual = 0.0008443110421, Final residual = 9.851206562e-18, No Iterations 5
what does it indicate for?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   June 16, 2013, 09:12
Retired Super Moderator
Bruno Santos
Hi Ehsan,
Uhm... isn't it the other way around? Low global and high local?
Almost a month ago, you had asked me about adding continuity to rhoCentralFoam. In one of the emails, I had sent the following explanation:
OK, from what I could figure out, the following code is needed:
  • #include "initContinuityErrs.H" //this is to be placed before the "while" loop
  • #include "compressibleContinuityErrs.H" //this is found in the "pEqn.H" file, after including "rhoEqn.H"
The two files are located at OpenFOAM's "src/finiteVolume/lnInclude/" folder.
Have a look into the file "$FOAM_SRC/finiteVolume/lnInclude/compressibleContinuityErrs.H" to see how it's calculated.
Best regards,
Bruno
immortality likes this.
Old   June 16, 2013, 09:32
Ehsan
Hi Bruno
I meant the accuracy.local has low accuracy.maybe wasn't careful enough!
rhoCentralFoam hasn't any difficulty in relation to continuity.both local and global continuity residuals are low enough,these results are from sonicFoam.
Old   June 16, 2013, 12:25
Bruno Santos
rhoCentralFoam does things in a very different way, at least from what I've vaguely read about it. If I'm not mistaken, it tends to smooth out the values (because it's "central", it takes into account more values from it's sides and the previous times?), which would be why the continuity would be well preserved.
But sonicFoam doesn't have this feature that rhoCentralFoam has got, which is probably why you're seeing larger continuity issues. Try reducing the "deltaT", to see if it has any effect. If it doesn't, then "fvSchemes" and the mesh itself should perhaps be the ones to blame?
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 21:51
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 04:13
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
