error in biconic25-55run35 tutorial case
why the original case doesn't execute?
Case : /home/ehsan/Desktop/biconic25-55Run35 |
Hi Ehsan,
Works fine for me and I tested with OpenFOAM 2.2.0. Perhaps you accidentally modified a file or perhaps you didn't run Allrun? Best regards, Bruno |
thanks.
I run it by ./Allrun now whats the callaoseDict?I can't understand this case. |
Do you mean "collapseEdgesDict"? It's for collapseEdges:
The other detail that's different from other tutorials is that the internal fields are already initialized with an almost resolved case. Check the file "README" to see what I mean. |
thanks.then collapseEdges is for something like modyfing mesh.
another question occurs that what is the role of blockMesh here when the points are specified in dat file. |
Here you go: http://www.cfd-online.com/Forums/ope...rmat-help.html
edit: I believe I explained this on that thread. |
