chtMultiRegionSimpleFoam
Old   June 18, 2013, 11:18
Default chtMultiRegionSimpleFoam
Samuele Z
samiam1000 is on a distinguished road
Dear All,
I am trying to set a multiregion simulation. It is a steady solution, hence I am using chtMultiRegionSimpleFoam.
The point is that I get this error:
lab@lab-laptop:~/Documenti/Ethics/FRISBEE/CFD/testVerticalTN_PCM/PCM/steady$ chtMultiRegionSimpleFoam
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.0-0bc225064152
Exec   : chtMultiRegionSimpleFoam
Date   : Jun 18 2013
Time   : 17:13:29
Host   : "lab-laptop"
PID    : 5389
Case   : /home/lab/Documenti/Ethics/FRISBEE/CFD/testVerticalTN_PCM/PCM/steady
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create fluid mesh for region fluid for time = 0
Create solid mesh for region pcm_1 for time = 0
Create solid mesh for region pcm_2 for time = 0
Create solid mesh for region pcm_3 for time = 0
*** Reading fluid mesh thermophysical properties for region fluid
    Adding to thermoFluid
Selecting thermodynamics package hRhoThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>
    Adding to rhoFluid
    Adding to kappaFluid
    Adding to UFluid
    Adding to phiFluid
    Adding to gFluid
    Adding to turbulence
Selecting turbulence model type RASModel
Selecting RAS turbulence model laminar
    Adding to ghFluid
    Adding to ghfFluid
--> FOAM FATAL ERROR:
LHS and RHS of - have different dimensions
     dimensions : [0 2 -2 0 0 0 0] - [1 -1 -2 0 0 0 0]
    From function operator-(const dimensionSet&, const dimensionSet&)
    in file dimensionSet/dimensionSet.C at line 535.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::error::abort() in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2  Foam::operator-(Foam::dimensionSet const&, Foam::dimensionSet const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#3  Foam::tmp<Foam::GeometricField<Foam::typeOfSum<double, double>::type, Foam::fvPatchField, Foam::volMesh> > Foam::operator-<double, double, Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/chtMultiRegionSimpleFoam"
#5  __libc_start_main in "/lib/libc.so.6"
Aborted
Where is the error, to you? It seems that I am setting wrong units of measurement to the BC. But where? Could you help?
Thanks,
Samuele
samiam1000 is offline   Reply With Quote
Old   July 9, 2013, 02:47
ZKW
Unnikrishnan
ZKW is on a distinguished road
Hi.
seems you have used the wrong dimensions for Pressure,
check 0/Fluid/p & 0/Fluid/p_rgh
p : dimensions [1 -1 -2 0 0 0 0];
p_rgh : dimensions [1 -1 -2 0 0 0 0];
as per the chtMultiRegionSimpleFoam tutorial.
openfoam211/tutorials/heatTransfer/chtMultiRegionSimpleFoam/multiRegionHeater/0
Regards
Unni
ZKW is offline   Reply With Quote
