-   -   interFoam error with imported Gambit mesh (http://www.cfd-online.com/Forums/openfoam-solving/119511-interfoam-error-imported-gambit-mesh.html)
shuoxue June 18, 2013 23:13
1 Attachment(s)
I am solving the damBreak tutorial in user guide with imported Gambit mesh.
Boundary conditions in boundary file have been rewrited.
This is .msh file generated in Gambit.
https://skydrive.live.com/?cid=a9e4f...4756B9AE%21105
setFields is ok.
Attachment 22810
Error occurs when I solve the case with interFoam.
luyao@luyao:~/OpenFOAM/luyao-2.2.0/run/case/multiphase-interFoam/1/damBreak2$ interFoam
| \\      /  F ield        | OpenFOAM: The Open Source CFD Toolbox          |
|  \\    /  O peration    | Version:  2.2.0                                |
|  \\  /    A nd          | Web:      www.OpenFOAM.org                      |
|    \\/    M anipulation  |                                                |
Build  : 2.2.0-5be49240882f
Exec  : interFoam
Date  : Jun 19 2013
Time  : 10:26:21
Host  : "luyao"
PID    : 4020
Case  : /home/luyao/OpenFOAM/luyao-2.2.0/run/case/multiphase-interFoam/1/damBreak2
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Reading g
Calculating field g.h
No finite volume options present
time step continuity errors : sum local = 0, global = 0, cumulative = 0
DICPCG:  Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
Courant Number mean: 0 max: 0
Starting time loop
Interface Courant Number mean: 0 max: 0
deltaT = 0.00119048
Time = 0.00119048
MULES: Solving for alpha1
Phase-1 volume fraction = 0.130194  Min(alpha1) = 0  Max(alpha1) = 1
DICPCG:  Solving for p_rgh, Initial residual = 1, Final residual = 0.0365699, No Iterations 3
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2  Uninterpreted:
#3  at tensorField.C:0
 in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/interFoam"
#7  __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
Thanks in advance.
nlinder June 19, 2013 07:08
Hi!
I have similar problems, but only with a modified interFoam solver so far. Interesting that it also happens with the standard solver. What are your boundary conditions?
Greetings
nlinder June 19, 2013 07:28
Update:
Can you confirm that commenting out the first two lines here (pEqn.H):
        if (pimple.finalNonOrthogonalIter())
            //phi = phiHbyA - p_rghEqn.flux();
            //U = HbyA + rAU*fvc::reconstruct((phig - p_rghEqn.flux())/rAUf);
            U.correctBoundaryConditions();
            fvOptions.correct(U);
"solves" the problem (at least the error message is gone - solution obviously not correct)?
The reason at this point is, that p_rghEqn.flux() returns a "-nan" field. Your first written timestep should be "-nan" everywhere in p_rgh, correct?
BTW: Serial or parallel?
greetings
nlinder June 19, 2013 09:30
Sorry for answering myself all the time but:
It seems as if
- ghf*fvc::snGrad(rho)
in "surfaceScalarField phig" produces an "-nan" on a boundary. Not in all cases, therefore I do not yet know where it comes from. Can you maybe confirm that in your case? Just comment it out and run again.
Greetings
Nicklas
shuoxue June 20, 2013 23:42
It seems as if
Greetings
Nicklas
Hi, nlinder!
I am afraid that we got different problems although we received similar error.
Mine has been solved, see here.
Which line do you want me to comment?
Both
and
nlinder June 21, 2013 03:48
Hi!
Allright, thanks for the information. In my case it was enough to comment out
I now specified a boundary condition for rho and in my testCase I had some issues with the pressure and Velocity BC. I think I somehow "solved" that problem currently.
Thanks for discussing :)
Nicklas
