-   -   DSMC Foam - HArd Sphere Model (http://www.cfd-online.com/Forums/openfoam-solving/119558-dsmc-foam-hard-sphere-model.html)
archeoptyrx June 19, 2013 15:07
Hello ppl,
I am new to OPENFOAM and i learning it through the tutorials .. I wish i could program by myself for different kind of flow problems .
In DSMCFOAM solver tutorials , for wedge15
// Wall Interaction Model
WallInteractionModel MaxwellianThermal;
// Binary Collision Model
BinaryCollisionModel LarsenBorgnakkeVariableHardSphere;
LarsenBorgnakkeVariableHardSphereCoeffs
Tref 300;
relaxationCollisionNumber 5.0;
If i wanted to change this model to Hard sphere model , what should i do ? ,
Also if i wanted to change the wall interaction model , what should i do ?
I understand that i should program the necessary model in the solver folder inside the installation directory ??? :confused::confused:
It will be great if some one help me out in this ..
Thanks
elfuertes June 24, 2013 04:59
Hi archeoptyrx !
First of all, you should look at the other submodels that are already implemented for dsmcFoam, they are in the $FOAM_SRC/lagrangian/dsmc/submodels folder.
If one of them suits you, just change the entry in your dmscProperties dictionnary, for instance :
WallInteractionModel SpecularReflection;
(and add the required options)
If you really need to add a new model, it will be more complicated.
See the following tutorial that can give you a few hints :
http://openfoamwiki.net/index.php/Ho...dary_condition
Good luck on that,
Sylvain
archeoptyrx July 3, 2013 16:45
Yes I got it . But how do i find the constants that has to be included with this ? .. eg
Binary collison model LArsonbarognke .......
what i should include here ? . How do i find the constants for this model ?
Is it same from the G A Bird book ??? Should i happen to give all the constants that is specified for this model in the book ??
Thanks for the help
sud
elfuertes July 5, 2013 03:59
As I said, you should take a look at the submodel's source code located in the folder :
"$FOAM_SRC/lagrangian/dsmc/submodels/"
For instance, for your specific example : if you look at the "LarsenBorgnakkeVariableHardSphere.C" source file, you will notice these lines in the constructor of this class :
template <class CloudType>
Foam::LarsenBorgnakkeVariableHardSphere<CloudType>::
    const dictionary& dict,
    CloudType& cloud
    BinaryCollisionModel<CloudType>(dict, cloud, typeName),
    Tref_(readScalar(this->coeffDict().lookup("Tref"))),
    relaxationCollisionNumber_
        readScalar(this->coeffDict().lookup("relaxationCollisionNumber"))
As you can see, you will need to provide "Tref" and "relaxationCollisionNumber" entries in the coeff dictionary.
I hope it will help, do not hesitate to look inside the source code and/or to run cases and analyse the output errors.
Sylvain
