Home > Forums > OpenFOAM Running, Solving & CFD
AMI-Rotary Spheroidal Interface
Old   June 24, 2013, 06:58
Default AMI-Rotary Spheroidal Interface
reza sadeghi
reza1111 is on a distinguished road
Hi everybody
I am new in OF and I am going to use OF AMI application.I know AMI uses cylindrical zone as an interface, but my rotary interface isn't cylindrical.
my case is a rotary spheroidal zone in a cubic domain. can I do my case using OF?
Please give me some hints about AMI ability.
Thanks in advance,
Reza
reza1111 is offline   Reply With Quote
Old   June 26, 2013, 07:28
reza sadeghi
any idea?
Old   July 9, 2013, 11:42
Artur's Avatar
Artur
Artur is on a distinguished road
I've never tried a spheroidal boundary but can give you a link to a post where I explained how I set up an AMi interface using an .stl file:
Query on SnappyHexMesh
After the steps described here I simply followed the propeller tutorial steps (topoSet, createPatch, createBaffles, mergeOrSplitBaffles -split).
I'm pretty sure if you make the .stl a sphere it would work. I'm also pretty sure, however, that you will have to choose your mesh settings very well and match them to the rotational speed of your mesh because otherwise you will suffer from floating point exceptions which occur when you get partial overlap of AMI faces (I was getting a lot of that with a poorly defined AMI itnerface).
Artur is offline   Reply With Quote
Old   July 19, 2013, 17:19
reza sadeghi
Thanks alot for your reply.
Thread Tools
Trackbacks are On
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
AMI speed performance danny123 OpenFOAM 19 October 24, 2012 07:44
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
