InterFoam - Gradient of Surface Field
Old   June 24, 2013, 10:28
Default InterFoam - Gradient of Surface Field
Thomas
Twist is on a distinguished road
Hi all!
I have a problem with the gradient of the surface field muEff. The original piece of code from InterFoam is
    surfaceScalarField muEff
        "muEff",
        twoPhaseProperties.muf()
      + fvc::interpolate(rho*turbulence->nut())
    fvVectorMatrix UEqn
        fvm::ddt(rho, U)
      + fvm::div(rhoPhi, U)
      - fvm::laplacian(muEff, U)
      - (fvc::grad(U) & fvc::grad(muEff))
    //- fvc::div(muEff*(fvc::interpolate(dev(fvc::grad(U))) & mesh.Sf()))
      - rho*g
Now I would expect that the following part of the fvSchemes would make an error:
gradSchemes
    default		none;
    grad(p)		Gauss linear corrected;
    grad(p_rgh)		Gauss linear corrected;
    grad(pcorr)		Gauss linear corrected;
    grad(U)		Gauss linear corrected;
    grad(alpha1)	Gauss linear corrected;
because the default is none and a grad(muEff) part is missing but it doesn't. The solver runs without an error. If I change muEff to a volScalarField I get the expected error and have to state a scheme for grad(muEff).
Is this a bug or did I just miss something?
Thanks!
Twist is offline   Reply With Quote
Diverging result for Temperature field in interFoam ovie OpenFOAM Running, Solving & CFD 105 December 6, 2021 09:02
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
estimating temp. gradient from temp. field xiyuqiu Main CFD Forum 2 April 12, 2013 17:22
Interfoam... free surface simulation urgent lostin4ever Main CFD Forum 4 October 12, 2010 08:29
Dynamic Gradient Adaption: Mulitple Field Variable Steve FLUENT 0 July 12, 2005 17:36
