June 25, 2013, 10:25 |
transient convergence criteria
Rep Power: 13 |
I'm working on a periodic simulation and I'd like to set up a temporal convergence criteria. It would be something like if variable(t+T)=variable(t) then stop simulation In the swak4foam library there are tools to stop a simulation if a criteria is reached, something like (in controlDict) : Code:
stopHighVel { type panicDump ; fieldName Q ; minimum -1; maximum 0.001; verbose true; } Regards, Florian |
June 25, 2013, 14:42 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
June 25, 2013, 15:28 |
Rep Power: 13 |
Thank you for writeAndEndSwakExpression, I didn't know this one. I'm still wondering how to access data at a specified time. oldTime only works for one timeStep in the past...
Any idea ? Regards, Florian |
June 25, 2013, 16:00 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Yep. Delayed variable
June 28, 2013, 12:14 |
Rep Power: 13 |
Thank you very much, a mix of delayedVariables and writeAndEndSwakExpression works perfectly !
Regards, Florian. |
June 28, 2013, 14:16 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Thank YOU. Without you I wouldn't have thought that delayed variables can be used for convergence-checking
June 29, 2013, 08:14 |
Anton Kidess
Rep Power: 29 |
Can you post the code? Might be useful for people in the future.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
June 29, 2013, 09:13 |
#8 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
July 2, 2013, 11:41 |
#9 | |
Rep Power: 13 |
Test case : one intlet with a sinusoidal pressure, 2 free outlets. Code:
stopIfCrit { type writeAndEndSwakExpression; valueType internalField; logicalExpression "(maxU1 < threshold) && (maxU2 < threshold) && (tt >= 1.5) && (test > 0.5) "; /* In this case 2 outlets are considered and tested. The (very basic) criteria used is the maximum velocity at the outlet patches. The flow is periodic and supposed physically converged if the criteria values are the same at t and t+T. The two first tests are the velocities comparison. The third one is a delay because of the unphysical behaviour that can appear at the beginning of the simulation. The fourth is used to keep the simulation running for one period after the convergence is reached.*/ logicalAccumulation and; variables ( "UA1fter{patch'outlet1}=max(mag(U));" //delayed criteria on outlet1 "Ub41{patch'outlet1}=max(mag(U));" // criteria on outlet1 "UA2fter{patch'outlet2}=max(mag(U));" "Ub42{patch'outlet2}=max(mag(U));" "maxU1=100*mag(UA1fter-Ub41)/mag(UA1fter);" "maxU2=100*mag(UA2fter-Ub42)/mag(UA2fter);" "threshold=5;" // 5% of difference accepted "tt=time();" "test=((maxU1 < threshold) && (maxU2 < threshold) && (tt >= 1.5))? 1 : 0;" // test done with a delay of T. ); delayedVariables ( { name UA1fter; delay 0.7; storeInterval 0.001; startupValue "100"; } { name UA2fter; delay 0.7; storeInterval 0.001; startupValue "100"; } { name test; delay 0.7; storeInterval 0.001; startupValue "0"; } ); verbose true; outputControlMode timestep; outputInterval 1; } With : blue = p(inlet), pink = 5% threshold, red and green : convergence criteria on both outlets. I was wondering : how can I add the period as a parameter ? Florian Last edited by Hiroshiman; July 2, 2013 at 15:31. |
July 2, 2013, 16:20 |
#10 | ||
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
defaultDelay 0.7; Code:
delay $defaultDelay;
July 4, 2013, 12:21 |
#11 | ||
Rep Power: 13 |
convcrit1 { type swakExpression; valueType patch; patchName outlet1; variables ( //"dummy=p-mag(U);" "UA1fter{patch'outlet1}=mag(U);" "Ub41{patch'outlet1}=mag(U);" ); delayedVariables ( { name UA1fter; delay 0.7; storeInterval 0.001; startupValue "100"; }); accumulations ( max ); expression "100*mag(UA1fter-Ub41)/mag(UA1fter)"; verbose true; autoInterpolate true; warnAutoInterpolate false; outputControlMode timestep; outputInterval 1; } Quote:
Florian |
July 8, 2013, 15:59 |
#12 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
April 8, 2015, 13:34 |
#13 |
Liam
Rep Power: 12 |
Hi everyone,
I am not understanding well the use of this wonderful tool. I would like to stop my (steady) simulation when Residuals are below a given threshold (let's say 1e-4) and outlet velocity remains unchanged with iterations, so, I have included this in my controDict file: velocity_outlet { type patchExpression; accumulations ( average ); patches ( out ); expression "mag(U)"; verbose true; outputControl timeStep; outputInterval 1; } This computes averaged outlet velocity as I desired. But now I am not sure how to compare old and present values. I would like to: if |uaveraged(iteration n)-uaveraged(iteration n-1)|<0.1 and Residuals<1e-4 then STOP Based on the code I have seen here, I have tried something like this( forget about the Residuals in this first try) stopIfCrit { type writeAndEndSwakExpression; valueType internalField; logicalExpression "(tol < threshold)"; logicalAccumulation and; variables ( "UA1fter=velocity_outlet;" //delayed criteria on outlet1 "Ub41=velocity_outlet;" "tol=mag(UA1fter-Ub41);" "threshold=0.5;" "test=((tol < threshold) )? 1 : 0;" ); delayedVariables ( { name UA1fter; delay 1; storeInterval 1; startupValue "1"; } { name test; delay 1; storeInterval 1; startupValue "0"; } ); verbose true; outputControlMode timestep; outputInterval 1; } But nothing happens. It seems that I am not telling OpenFOAM when it has to stop .This definition I have tried looks so weird: "UA1fter=velocity_outlet;" //delayed criteria on outlet1 "Ub41=velocity_outlet;" Does anybody know how I have to proceed to compare a computed value in the previous iteration with this value in the current iteration? Thanks in advance! |
April 8, 2015, 14:03 |
#14 | |
Rep Power: 13 |
Hi, you can look at the variables values that are stored during the simulation to check if they are what you expect (in the swak4Foam folder at each timeStep). You can use the [CODE ] [/CODE ] bracket to make the code readable. |
April 8, 2015, 14:45 |
#15 |
Liam
Rep Power: 12 |
Hi Hiroshiman,
The values of: velocity_outlet { type patchExpression; accumulations ( average ); patches ( out ); expression "mag(U)"; verbose true; outputControl timeStep; outputInterval 1; } are written in postProcessing folder (no swak4foam folder in my case) The problem is I don't know how to use this values to stop my simulation when differences between consecutive iterations is small. Some more help will be much aprecciated. |
Display Modes | |
transient convergence | mohsen.samie | CFX | 8 | September 15, 2015 11:18 |
What is the criteria for convergence in transient problems? | abcd | ANSYS | 0 | July 26, 2015 13:03 |
SIMPLE algorithm, convergence criteria | bbasal | Main CFD Forum | 3 | December 3, 2011 00:24 |
What value shall I set for the Convergence criteria? | steventay | CFX | 7 | May 14, 2010 13:44 |
Convergence Criteria | edwin | FLUENT | 1 | February 14, 2008 20:24 |
