-   -   problem running blockMesh in ubuntu terminal (openfoam) (http://www.cfd-online.com/Forums/openfoam-solving/119859-problem-running-blockmesh-ubuntu-terminal-openfoam.html)
subhsngh June 26, 2013 06:34
i am new to ubuntu and openfoam.i was trying to run a compressible simulation . when i tried to run blockMesh of rhoSimplecFoam the follwing errror was shown in terminal window
subh@subh-VirtualBox:~$ cd OpenFOAM/subh-2.2.0/run/rhoSimplecFoam
subh@subh-VirtualBox:~/OpenFOAM/subh-2.2.0/run/rhoSimplecFoam$ blockMesh
| \\ / O peration | Version: 2.2.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.2.0-b363e8d14789
Exec : blockMesh
Date : Jun 26 2013
Time : 16:02:42
Host : "subh-VirtualBox"
PID : 3615
Case : /home/subh/OpenFOAM/subh-2.2.0/run/rhoSimplecFoam
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/subh/OpenFOAM/subh-2.2.0/run/rhoSimplecFoam/system/controlDict at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
please help me
thanks
-mAx- June 26, 2013 07:27
cannot find file
do you have controlDict File under /system ?
subhsngh June 26, 2013 07:34
yes it is in system
-mAx- June 26, 2013 07:40
are you running blockMesh in the case directory?
If it is squareBend, then you have to go and run blockMesh in the case directory, ie:
cd squareBend
subhsngh June 26, 2013 07:49
thank you it's working....
can you please tell me what should i use to develop a simulation for studying heat properties of a porous medium in a cylndrical tank ..and yes it is compressible
i am working on a project in my college.....so i would be very happy
-mAx- June 26, 2013 07:51
i would open a new thread with explicit subject in the right subforum
subhsngh June 26, 2013 08:02
thank you
subhendu
