problem running blockMesh in ubuntu terminal (openfoam) |
June 26, 2013, 06:34 |
subhendu
Rep Power: 12 |
i am new to ubuntu and openfoam.i was trying to run a compressible simulation . when i tried to run blockMesh of rhoSimplecFoam the follwing errror was shown in terminal window
subh@subh-VirtualBox:~$ cd OpenFOAM/subh-2.2.0/run/rhoSimplecFoam subh@subh-VirtualBox:~/OpenFOAM/subh-2.2.0/run/rhoSimplecFoam$ blockMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0-b363e8d14789 Exec : blockMesh Date : Jun 26 2013 Time : 16:02:42 Host : "subh-VirtualBox" PID : 3615 Case : /home/subh/OpenFOAM/subh-2.2.0/run/rhoSimplecFoam nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM FATAL IO ERROR: cannot find file file: /home/subh/OpenFOAM/subh-2.2.0/run/rhoSimplecFoam/system/controlDict at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting subh@subh-VirtualBox:~/OpenFOAM/subh-2.2.0/run/rhoSimplecFoam$ please help me thanks |
June 26, 2013, 07:27 |
Maxime Perelli
Rep Power: 41 |
do you have controlDict File under /system ?
In memory of my friend Hervé: CFD engineer & freerider |
June 26, 2013, 07:34 |
subhendu
Rep Power: 12 |
yes it is in system
June 26, 2013, 07:40 |
Maxime Perelli
Rep Power: 41 |
are you running blockMesh in the case directory?
If it is squareBend, then you have to go and run blockMesh in the case directory, ie: cd squareBend
June 26, 2013, 07:49 |
subhendu
Rep Power: 12 |
thank you it's working....
can you please tell me what should i use to develop a simulation for studying heat properties of a porous medium in a cylndrical tank ..and yes it is compressible i am working on a project in my college.....so i would be very happy |
June 26, 2013, 07:51 |
Maxime Perelli
Rep Power: 41 |
i would open a new thread with explicit subject in the right subforum
June 26, 2013, 08:02 |
subhendu
Rep Power: 12 |
thank you
subhendu |
[OpenFOAM] Problem switching from terminal to paraView | Maxime Thomas | ParaView | 10 | October 4, 2014 10:59 |
Installation problem - calling blockMesh - libblockMesh.so | aylalisa | OpenFOAM Installation | 5 | November 28, 2012 09:55 |
Installing OpenFOAM 1.6 on Ubuntu 10.4 | sda | OpenFOAM Installation | 5 | May 27, 2010 20:19 |
Install openFOAM 1.6 on debian 32bit - blockMesh: command not found | fossy | OpenFOAM Installation | 1 | August 28, 2009 04:06 |
Problem in running fluent 6.3 (64 bit) on ubuntu 8.1 (64 bit) | Mir5 | FLUENT | 3 | April 29, 2009 10:32 |
