April 19, 2010, 05:36 |
sonicFoam not matching shock theory
Alan Harrland
Rep Power: 17 |
Hi all,
I am trying to use sonicFoam for some inviscid simulations, and my test case (supersonic flow over a wedge) does not seem to be following the analytical solution. I am simulating a 14.03 deg wedge at Mach 7, sea level atmospheric conditions. If you look at the image below, it shows that the shock sits lower than the analytical solution (the line source). I can adjust the thermophysical properties get the shock to sit in the right position, but this does not give me much faith in other solutions! My thermophysical properties are: Code:
thermoType ePsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>; mixture air 1 28.96 1005 0 0 0.715; Does anyone have any ideas as to what could be causing this? I have simulated the same wedge in other solvers (rhoCentralFoam and rhopSonicFoam) and the results match the analytical theory. Thanks in advance for any help, Alan |
April 20, 2010, 02:25 |
Alberto Passalacqua
Rep Power: 36 |
Hello, I'm sorry to answer with a question: what does rhoSonicFoam does?
The major difference I can see between the solvers you used is that rhopSonicFoam and rhoCentralFoam solve for conserved variables, while sonicFoam does not. I hope this additional test can help to clarify. Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
April 20, 2010, 04:57 |
Alan Harrland
Rep Power: 17 |
April 22, 2010, 00:44 |
Alberto Passalacqua
Rep Power: 36 |
Interesting.
To exclude a possibility: in your run in rhoCentralFoam, did you set thermoPhysical properties to the same data you report for air (some tutorials use the normalised gas)? Best,
April 24, 2010, 05:52 |
Alan Harrland
Rep Power: 17 |
Hi Alberto,
If I run the wedge in rhoCentralFoam with the same thermophysical properties as my sinicFoam case (i.e. not normalised) then the shock matches the theory. It appears to be a problem with the sonicFoam solver, as it gives the same (incorrect) shock position in both normalised and regular thermophysical properties. Thanks again for your help, it is much appreciated. |
April 24, 2010, 08:36 |
Alberto Passalacqua
Rep Power: 36 |
If there is no bug, it might be related to how the equations are discretized, as I said before, but it's just a guess.
I'd suggest to use codes with the conservative form of the equations for shock capturing. Best,
April 26, 2010, 04:12 |
Try tutorial
Rep Power: 16 |
I tried sonicFoam on OF-1.3, shock tube case in tutorial. It gives the wrong result (as said before, probably due to the fact that scheme is not conservative).
I checked against exact solution, obtained from C-code in the link below http://num.math.uni-goettingen.de/kn...ro_ss2006.html Haven't checked later versions (but that would be easy to do). |
April 26, 2010, 07:27 |
Alan Harrland
Rep Power: 17 |
So is there a way to fix this? sonicFoam seems to be the obly stable solver for my problem, the others seem to get anomalies in the solution that diverge
April 26, 2010, 09:11 |
#9 |
Rep Power: 16 |
April 26, 2010, 17:31 |
#10 |
Alan Harrland
Rep Power: 17 |
Well, in rhoCentralFoam I am unable to progress the solution without it crashing within a few iterations (getting a maximum number of iterations exceeded error). This is the error I get:
Create time Create mesh for time = 0.00264945 Reading thermophysical properties Selecting thermodynamics package ePsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>> Maximum number of iterations exceeded#0 Foam::error::printStack(Foam::Ostream&) in "/home/aharrland/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/aharrland/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Foam::ePsiThermo<Foam::pureMixture<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::calculate() in "/home/aharrland/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libbasicThermophysicalModels.so" #3 Foam::ePsiThermo<Foam::pureMixture<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::ePsiThermo(Foam::fvMesh const&) in "/home/aharrland/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libbasicThermophysicalModels.so" #4 Foam::basicPsiThermo::addfvMeshConstructorToTable<Foam::ePsiThermo<Foam::pureMixture<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > > >::New(Foam::fvMesh const&) in "/home/aharrland/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libbasicThermophysicalModels.so" #5 Foam::basicPsiThermo::New(Foam::fvMesh const&) in "/home/aharrland/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libbasicThermophysicalModels.so" #6 main in "/home/aharrland/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/rhoCentralFoam" #7 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #8 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122 From function specieThermo<thermo>::T(scalar f, scalar T0, scalar (specieThermo<thermo>::*F)(const scalar) const, scalar (specieThermo<thermo>::*dFdT)(const scalar) const) const in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 68. FOAM aborting This is what the simulation looks like in rhopSonicFoam: Note the 'stagnation' points at the top of the compression wedge. These slowly over the time of the solution go to zero, causing the time step (with adjust time step on) to go to a very large number. Here is the simulation in sonicFoam: This gives a nice stable solution, although with the incorrect shock angle. I have a well refined, structured mesh, so I do not believe this to be the problem. This is also only a simple case which I need to expand to much more complex geometries, so the apparent stability of sonicFoam is quite appealing to me. Thanks for your help KrisT. |
April 26, 2010, 17:32 |
#11 |
Alan Harrland
Rep Power: 17 |
April 26, 2010, 21:48 |
#12 |
Alberto Passalacqua
Rep Power: 36 |
In rhoCentralFoam, what is giving troubles to you seems to be the energy equation, given the error message you obtain. Is it converging before the crash?
Are you performing inviscid runs in rhoCentralFoam? It seems to me the behaviour at the walls is different. Additionally, could you show a zoom of the mesh with the solution under it (Surface with edges in paraview) around the tip of the triangle at the exit (where rhoCentralFoam has a sort of blue circle in the solution). Best, Alberto
April 26, 2010, 22:47 |
#13 |
Alan Harrland
Rep Power: 17 |
Hi Alberto,
Im not sure what you mean by 'is it converging before the crash?'. Do you mean is the energy equation converging, or is the entire solution converging? I am solving this case as inviscid, as far as I am aware rhoCentralFoam is only an inviscid solver? My wall BC's are slip for the velocity file, and zeroGradient for p and T. Here is the image that you asked for (note the flow is from left to right, so this is at the inlet, not the outlet): I have also attached a similar picture around the entry to the isolator, which is the area of flow I believe is giving the solvers all the trouble. Thanks again for your help Alberto, it is very much appreciated. Alan |
April 26, 2010, 23:04 |
#14 | |||
Alberto Passalacqua
Rep Power: 36 |
Best, Alberto
April 27, 2010, 02:03 |
Ramp up Mach number?
#15 |
Rep Power: 16 |
Maybe I'm stupid here, but what happens if you ramp up the Mach number?
Would you get a stable solution for a lower Mach number? Is it possible to specify varying (increasing) inlet Mach number? /j |
June 27, 2013, 07:10 |
#16 |
Ehsan
Rep Power: 26 |
Hi Alan
although a somewhat old thread.but I saw the same problem when a moving shock goes near the wall.residuals of U.x and h increases,although crashing doesn't occur.I use maxCo too. has had anyone this problem too to share? well,then sonicFoam solves only non-conservative form of equations.that was a very good information you gave to me!
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
energy in sonicFoam | joern | OpenFOAM Running, Solving & CFD | 1 | September 24, 2019 00:15 |
HLL Riemann Shock Tube Matlab Problem | Luke F | Main CFD Forum | 2 | May 20, 2016 02:10 |
Shock Fitting | Craig | FLUENT | 1 | April 24, 2008 17:06 |
Will compression waves overtake a moving shock? | GRA | Main CFD Forum | 2 | October 19, 2006 00:24 |
Shock capturing | Dr B.M. Smith (Smith) | OpenFOAM Running, Solving & CFD | 1 | December 10, 2004 05:40 |
