-   -   getting wrong value of drag (http://www.cfd-online.com/Forums/openfoam-solving/120072-getting-wrong-value-drag.html)
shash June 29, 2013 20:08
Hi openfoamers,
I am simulating a 3d flow around a sphere enclosed in a large cube, but problem is that i am getting my drag =1.04 instead of expt. drag =0.66 for reynolds no. of 300, parameters: fluid:air with rho=1.2, nu=1e-04, dia. of sphere=1m, velocity at inlet=0.03m/s ; Can someone please suggest what i am doing wrong.
my controldict where drag lib parameters given :
application icoFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 50;
deltaT 0.005;
writeControl timeStep;
writeInterval 200;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
functions
forces
type forceCoeffs;
functionObjectLibs ("libforces.so");
enabled true;
outputControl timeStep;
outputInterval 1;
patches (sphere);
rhoName rhoInf;
rhoInf 1.2;
log true;
CofR (0 0 0);
liftDir (0 1 0);
dragDir (1 0 0);
pitchAxis (0 0 0);
magUInf 0.03;
lRef 1;
Aref 0.785;
immortality June 29, 2013 20:45
what does vortices look like?is there any?
shash June 30, 2013 16:28
Hi Ehsan,
you pointed out correctly, i donot know why i am not getting the double threaded vortices for Re =300 thou with similar settings i have got as expected karman vortex street in 2d case. Got any ideas whats wrong when i am using 3d geometry??
immortality June 30, 2013 16:43
Hi Shiv
are you using a turbulent model?which?how-Re or low-Re?
shash June 30, 2013 17:22
no, i am using icofoam solver so its laminar flow.
Ehsan, i noted something that when i use [nu=1e-04, U=0.03, Re=300] i am not getting vortices though when i use [nu=0.01, U=3, Re=300] i am getting vortices , both the cases have same Re why variation in results :confused:
immortality July 1, 2013 11:26
its unsteady if wakes there are.maybe deltaT isn't low enough.
