Home > Forums > OpenFOAM Running, Solving & CFD
ReactingFoam & Dynamic Mesh
Old   July 1, 2013, 05:57
Default ReactingFoam & Dynamic Mesh
Jacopo
yaqb is on a distinguished road
Hello All !
I am trying to run reactingFoam with dynamic Mesh.
My basic idea is very simple - I would like to simulate the regression rate of the fuel during the burning process.
I set dynamicMeshDict
| \\ / O peration | Version: 2.1.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object dynamicMeshDict;
dynamicFvMesh dynamicMotionSolverFvMesh;
motionSolverLibs ( "libfvMotionSolvers.so" );
solver velocityLaplacian;
diffusivity uniform;
,and run it, but all the time get the same error:
--> FOAM FATAL ERROR:
Different dimensions for +=
dimensions : [1 0 -1 0 0 0 0] = [0 3 -1 0 0 0 0]
From function dimensionSet:perator+=(const dimensionSet&) const
in file dimensionSet/dimensionSet.C at line 241.
FOAM aborting
Do you have any idea where can I search for the mistake?
In BC there is no parameter with dimensions [1 0 -1 0 0 0 0] , so I am not sure what does the solver wants from me?
yaqb is offline   Reply With Quote
Old   July 1, 2013, 11:28
Nima Samkhaniani
nimasam is on a distinguished road
OpenFOAM analyses for dimension compatibility, so before it solves an equation, it investigates whether parameters have the same dimension of not ,
so check it with out dynamic mesh, maybe your input dimension for p, u r something else is wrong, i think its not related to dynamic mesh
Telegram channel (https://telegram.me/openfoam4Iranian)
My Weblog (http://openfoam.blogfa.com/)
Training Course on OpenFOAM at (http://www.isme.ir/)
nimasam is offline   Reply With Quote
Old   July 1, 2013, 12:06
Jacopo
Thanks for the replay!
In fact if I just run pure reactingFoam case than it works perfect however when I try to use reactingFoamDynamic it crashes.
There is only one additional BC added - pointMotionU - responsible for the mesh motion.
| \\ / O peration | Version: 2.1.1 |
FoamFile
version 2.0;
format ascii;
class pointVectorField;
object pointMotionU;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
fuel
type fixedValue;
value uniform (0.1 0 0);
air
type fixedValue;
value uniform (0 0 0);
outlet
type fixedValue;
frontAndBack
type empty;
Up
type fixedValue;
Bottom
type fixedValue;
And here it is m/s so everything seems to be ok. Any idea where I should search for the mistake?
Old   July 1, 2013, 12:17
Nima Samkhaniani
post your test case here
Old   July 1, 2013, 12:30
Jacopo
Here it is
Thread Tools
Trackbacks are On
Dynamic Mesh "Shadow Wall" thezack FLUENT 0 June 4, 2013 22:09
dynamic mesh for drop interface IndrajitW FLUENT 0 March 30, 2013 09:03
Dynamic Mesh on Pintle type injector. herntan FLUENT 15 January 4, 2012 04:31
pls help. mesh collapsed with dynamic mesh. wlt_1985 FLUENT 1 July 28, 2011 01:53
dynamic mesh on a hexa grid Manoj Kumar FLUENT 0 August 21, 2007 07:41
