June 7, 2013, 15:46 |
rhoSimpleFoam pipe flow crashing
Sam
Rep Power: 12 |
I have a simple pipe flow model that works fine in fluent but crashes OpenFOAM. The model is attached.
Here are the commands to run the case in OpenFoam 2.1.1: blockMesh surfaceFeatureExtract -includedAngle 150 ./constant/triSurface/surface.stl surface.eMesh snappyHexMesh -overwrite transformPoints -scale "(.001 .001 .001)" renumberMesh -overwrite rhoSimpleFoam The model runs to about 200 iterations, crashes and the output fields are clearly not headed in the right direction. I've tried the following: - first order - potentialFoam - a variety of setting changes suggested on the forums Any help would be appreciated. Thanks, Sam |
June 8, 2013, 17:43 |
VS
Rep Power: 13 |
Sam,
i've checked only your controlDict file, because i had the same problem when i used rhoSimpleFoam. First of all, i suggest you lower your timestep, even put a constrain of max Courant 0.5 or 1. I strongly believe this could fix your problem, since your BCs are sufficient. I wait for your results. |
June 19, 2013, 10:16 |
Solved
Sam
Rep Power: 12 |
I reduced the rho relaxation factor to 0.05 and ran the model in 2.2. The results now look correct.
-Sam |
July 1, 2013, 15:37 |
Incorrect transport properties for air
Sam
Rep Power: 12 |
The transport properties should have been:
transport { As 1.458e-06; // C1 Coefficient Ts 110.4; // C2 Coefficient } That change plus the relaxation change brings the result within 30% of the fluent and test results. This is still not close enough in my opinion... I have attched a new version of the analysis. Again the commands to reproduce are: blockMesh surfaceFeatureExtract -includedAngle 150 ./constant/triSurface/surface.stl surface.eMesh snappyHexMesh -overwrite transformPoints -scale "(.001 .001 .001)" renumberMesh -overwrite rhoSimpleFoam |
Pipe flow with obstacle - HELP | Min | FLUENT | 6 | January 31, 2017 14:28 |
compressible flow calculation error using rhoSimpleFoam solver | student4326 | OpenFOAM Running, Solving & CFD | 7 | November 2, 2015 11:34 |
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry | mazhar1613 | ANSYS Meshing & Geometry | 1 | January 11, 2012 23:18 |
[ASK] Flow in Corrugated Pipe with FLUENT | Primadhani | FLUENT | 1 | May 11, 2011 20:41 |
Pipe Flow | Saima | CFX | 1 | January 10, 2011 16:41 |
