Moving Heat Source on a CV
Hello together,
I'm completely new in using OpenFoam and faced with a (I hope simple) problem I don't know how to continue. My case is to simulate a simple heat conduction welding process where I want to simulate in a first step a moving heat source (Point source or circle) on the surface of a control volume (CV). I've chosen the laplacianFOAM solver because I don't want to consider any convective parts. For that issue. I've implemented a source term q in the standard laplacianFOAM solver and boundaries. But how is the approach for using this term as a moving source? Do I need a moving "meshgrid" on the CV or maybe inside (Volume source) or can I solve this by boundary conditions? Thanks a lot for answers. Tomster |
Update: Maybe fvOptions as a solution?
Hello again,
after one more day of searching on a lot of sites I found an approach for my problem using the fvOptions framework. I'll try it with the simpleScalarFOAM because the solver includes a fvOptions (T) - source-term. Anyway - does anybody have a good conclusion or an idea where I can find a "manual" how I've to set der fvOptions dictionary file to create a moving heat source? Thanks again for any reply. |
Hi Tomster,
It's easy to model the moving heat source. If your heat source is a surface heat source, then you can impose it as a boundary condition, then groovyBC [http://openfoamwiki.net/index.php/Contrib_groovyBC] will be more helpful for you. Just look at the groovyBC sites. In case of volumetric heat source, you can easily use "expressionSource"- which comes with the swak4Foam [http://openfoamwiki.net/index.php/Contrib/swak4Foam]. So, what you need to construct the expression for moving source, then use the method that comply your need. Cheers! |
How to implement something from swak4Foam?
Hey Ahmmedshakil,
thanks a lot for you suggestion! I'm completely new in OpenFoam and I have after a couple of days reading no idea how I have to implement this function :( I'm sorry, but the structure of OF is not easy to understand... In the first step, I've downloaded and compiled swak4foam (with ./Allwmake). But where and how do I have to implement the Code? I want to use your suggested expressionSource.H for adding a moving volumetric heat source. - Is the source itself (size, moving parameters) described in a library in the run/case-folder? - Do I have to change something in the laplacianFoam.C? - Should I add something in the ./Make/files oder options-file? - What is to to in the case-folder? Thank you for answering my noob-questions ;) Greetings, Tomster |
Hi Tomster,
For using expressionSource, there is a example done in swak4Foam-->Examples-->interFoamWithSources. And you can easily take help from this post: http://www.cfd-online.com/Forums/ope...urce-term.html. Cheers! |
How does it work?
Hello Ahmmedshakil,
thank you again for replying my post. Unfortunately it does not work :( I'll now exactly describe what I've done from the beginning - maybe you find my mistake: - I've downloaded the swak4Foam files (Version 0.2.3) from http://openfoamwiki.net/index.php/Contrib/swak4Foam as a *.tar-file and unpacked it in the $HOME/swak4foam directory (and stayed the files later here) - As mentioned, I commented out the #define FOAM_LOOKUPCLASS_NO_CONST in the Libraries/swak4FoamParsers/include/swak.H file - I compiled swak4Foam with ./Allwmake (It took around 10 Minutes!?) - For my case, I followed the instructions from gschaider in this post: http://www.cfd-online.com/Forums/ope...urce-term.html - Now these are my files: createFields.H Code:
Info<< "Reading field T\n" << endl; Code:
\*---------------------------------------------------------------------------*/ Code:
EXE_INC = \ Another Problem is that I can't run the suggested Example in ./interFoamWithSources. What do I have to do that it will work? Thank you again very much - I hope my questions will help other noobs in understanding OpenFoam with swak4Foam :rolleyes: (Afer success I'll publish my code here). Greetings |
Hi Tomster,
The error message :(Error Message: expressionSource.H not found)--- so you have problem in the linking file i.e. EXE_INC = \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$HOME/swak4Foam/Libraries/swakSourceFields/InInclude (PLEASE CHECK HERE) EXE_LIBS = \ -lfiniteVolume \ -L$FOAM_USER_LIBBIN The same thing is true for the example running.... I'm sure now you can run the solver. cheers!! |
transient heat source
Where u defined the heatSourceDict and how. I am new to OpenFoam and please tell me the step you follow to add the transient heat source into LaplacianFoam. Kumudu Quote:
Transient heat source
Hi Tomster0815,
I did exactly what you said. But I got this error. Please tell me how to fix this. Kumudu kumudu21688@kumudu21688-Inspiron-N5040:~/OpenFOAM/kumudu21688-2.1.1/run/myheatsource$ mylaplacianFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.1-221db2718bbb Exec : mylaplacianFoam Date : Nov 03 2013 Time : 11:01:29 Host : "kumudu21688-Inspiron-N5040" PID : 4536 Case : /home/kumudu21688/OpenFOAM/kumudu21688-2.1.1/run/myheatsource nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field T Reading transportProperties Reading diffusivity DT SIMPLE: no convergence criteria found. Calculations will run for 15 steps. Calculating temperature distribution swak4Foam: Allocating new repository for sampledSets --> FOAM FATAL IO ERROR: Attempt to return dictionary entry as a primitive file: /home/kumudu21688/OpenFOAM/kumudu21688-2.1.1/run/myheatsource/system/controlDict::functions::theSensor::setName from line 59 to line 63. From function ITstream& primitiveEntry::stream() const in file db/dictionary/dictionaryEntry/dictionaryEntry.C at line 82. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::IOerror::abort() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 Foam::dictionaryEntry::stream() const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #3 Foam::SetsRepository::getSet(Foam::dictionary const&, Foam::polyMesh const&) in "/home/kumudu21688/OpenFOAM/kumudu21688-2.1.1/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so" #4 Foam::createSampledSet::createSampledSet(Foam::wor d const&, Foam::objectRegistry const&, Foam::dictionary const&, bool) in "/home/kumudu21688/OpenFOAM/kumudu21688-2.1.1/platforms/linux64GccDPOpt/lib/libswakFunctionObjects.so" #5 Foam::OutputFilterFunctionObject<Foam::createSampl edSet>::allocateFilter() in "/home/kumudu21688/OpenFOAM/kumudu21688-2.1.1/platforms/linux64GccDPOpt/lib/libswakFunctionObjects.so" #6 Foam::OutputFilterFunctionObject<Foam::createSampl edSet>::start() in "/home/kumudu21688/OpenFOAM/kumudu21688-2.1.1/platforms/linux64GccDPOpt/lib/libswakFunctionObjects.so" #7 Foam::functionObjectList::read() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #8 Foam::Time::run() const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #9 Foam::Time::loop() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #10 Foam::simpleControl::loop() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #11 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/mylaplacianFoam" #12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #13 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/mylaplacianFoam" Aborted (core dumped) Quote:
