Home > Forums > OpenFOAM Running, Solving & CFD
OpenChannel with Two Cylinders in icoFoam
Old   July 7, 2013, 12:54
Nima Samkhaniani
nimasam is on a distinguished road
Originally Posted by jimbean View Post
Hi Nimasam,
Thanks for the suggestion.
Could you help me check this case?
I attached the link,
https://www.dropbox.com/s/5m2vw11e6a...ylinder.tar.gz
well, check your mesh, again, you assign a wrong patch as out-flow
Telegram channel (https://telegram.me/openfoam4Iranian)
My Weblog (http://openfoam.blogfa.com/)
Training Course on OpenFOAM at (http://www.isme.ir/)
nimasam is offline   Reply With Quote
Old   July 7, 2013, 13:02
Nima Samkhaniani
Originally Posted by subhsngh View Post
i am posting my case
your mesh has wrong assigned patch, also severely non-orthogonal face, build new mesh
Old   July 7, 2013, 23:00
Zhengbing
jimbean is on a distinguished road
How didi you find the wrong boundary.
I was using checkMesh, and it looks everything is ok.
jimbean is offline   Reply With Quote
Old   July 8, 2013, 00:29
Nima Samkhaniani
your mesh configure is fine, as i said before, you assigned wrong patch as out-flow, you can see each patch by paraview, just click on patch name , and remove other patch name on paraview
Old   July 8, 2013, 08:05
Zhengbing
Hi Nimasam,
Thank you.
I changed the out-flow patch.
And now it can calculate, but some problems still exist, see figures below
There is no flow in the area (blue region) around the cylinders (represented by the gray circle). I have double checked the wall boundary, and it's right. So what's wrong with the blue region?
In the second figure, large velocity is found at the surface. Note different scale for these two figures. I gave a symmetryPlane boundary for the surface. Why did it cause big value at the surface?
If you want, find the case at
https://www.dropbox.com/s/vb3ge8jm4t...linders.tar.gz
Old   July 9, 2013, 04:47
Nima Samkhaniani
i feel you need to increase cells number in z direction to atleast 4 cells, maybe it solves your problem
Old   July 9, 2013, 10:22
Zhengbing
Hi Nima
I increased the cells number in z direction to 8, but it didn't work.
Do you have any other ideas on this?
Thank you.
Thread Tools
Trackbacks are On
2D Aerofoil with rotating cylinders - Help & Advice! Bluejay OpenFOAM 1 December 31, 2012 05:40
Density in icoFoam Densidad en icoFoam manuel OpenFOAM Running, Solving & CFD 8 September 22, 2010 04:10
[ICEM] generating tetra mesh on various cylinders at the same time karananand ANSYS Meshing & Geometry 2 July 9, 2010 16:34
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
