under what circumstances would interFoam have alpha > 1?
Like Tree3Likes
  • 1 Post By yanxiang
  • 2 Post By duongquaphim
Old   February 21, 2013, 15:04
Default under what circumstances would interFoam have alpha > 1?
yanxiang is on a distinguished road
Dear Foamers,
As per the title, in OF211, what would make the alpha go above 1 when using interFoam? Shouldn't the MULES solver ensure the volume fraction be bounded at all times?
I constantly get unbounded alpha when trying to simulating a microscale reactor with good quality mesh. Sometimes it could go up to 6 or even higher if allowed to run longer. I partially solved the problem by changing the mesh/BC. However, it is good to know what causes this issue.
Thanks,
Yanxiang
lourencosm likes this.
yanxiang is offline   Reply With Quote
Old   July 15, 2013, 16:29
Duong A. Hoang
duongquaphim is on a distinguished road
Send a message via Yahoo to duongquaphim
Are you running cases with the same settings as in the damBreak tutorial? Could you put the case here such that I can give it a try? I never had any things like that.
Also for the term div(phi,alpha), using vanLeer01 instead of vanLeer might be helpful. This might also be helpful http://www.cfd-online.com/Forums/ope...erdymfoam.html
Regards,
Duong
vbnhfylbh and lourencosm like this.
duongquaphim is offline   Reply With Quote
alpha becomes bigger than 1 in interFoam ata OpenFOAM 1 March 21, 2020 14:49
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
InterFoam negative alpha karasa03 OpenFOAM 7 December 12, 2013 03:41
Moving from simpleFoam to interFoam with alpha = 0 kjetil OpenFOAM Running, Solving & CFD 1 November 8, 2009 20:04
alpha or alpha1 in interFoam & interDyMFoam wavytracy OpenFOAM Bugs 3 September 10, 2009 02:51
