Diffent Results between OpenFOAM and Fluent
Old   July 11, 2013, 12:01
Default Diffent Results between OpenFOAM and Fluent
Julio Silveira
biau is on a distinguished road
I am currently doing a simulation (airfoil) to compare between openfoam and fluent.
The mesh was done in ICEM and converted to openfoam format using fluentmeshtofoam. However, when the mesh was converted it was expanded in the z-direction by 0.57m (It extruded from -0.28 to 0.28 in z-direction) and it kept the length as 1m.
After setting up the simulation and running it, I can't get results that are similar to Fluent results (e.g. In fluent Cl =0.507, Cd=0.027 and in OF Cl= 0.326 Cd=0.0123). I tried to use different reference areas (1m2, 0.57m2, 1.57m2). But the area that gave me the best results was 0.28m2. Is there a way to find out what is the correct reference values to use when setting up the case ? I tried to use paraview to get the surface area of the top part of the airfoil and it was 0.57m.
I am trying to run the simulation inviscid and the case and mesh files are in the link below.
https://www.dropbox.com/sh/4wbivcwswkwvgvf/PV7niWNfZ5
Any help would be appreciated.
Thank you
Julio
biau is offline   Reply With Quote
Old   July 12, 2013, 04:01
Julio Silveira
Anyone please ?
Old   July 12, 2013, 08:30
Aurelien Thinat
Aurelien Thinat is on a distinguished road
Hi Julio,
Few things to start with :
- did you check the material properties in OF and Fluent ?
- did you run a checkMesh ?
- I have never used the "freestream" boundary conditions before. Have you tried to use :
velocity : fixedValue at the inlet BC and inletOutlet at outlet BC
pressure : fixedValue at the outlet BC zerogradient at the inlet BC
Aurélien
Aurelien Thinat is offline   Reply With Quote
Old   July 12, 2013, 09:02
Julio Silveira
Originally Posted by Aurelien Thinat View Post
Hi Julio,
Aurélien
Dear Aurelien,
I did check the material properties, there is a slightly difference in temperature and density, however I made adjustments to make sure they are the same.
I did run meshCheck
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
internal points: 0
faces: 65792
internal faces: 32512
cells: 16384
boundary patches: 4
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 16384
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
outlet 128 258 ok (non-closed singly connected)
inlet 256 514 ok (non-closed singly connected)
wing_profile 128 256 ok (non-closed singly connected)
frontAndBackPlanes 32768 33280 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-10 -10 -0.2864000698) (10.5 10 0.2864000698)
Mesh (non-empty, non-wedge) directions (1 1 0)
Mesh (non-empty) directions (1 1 0)
All edges aligned with or perpendicular to non-empty directions.
Boundary openness (-3.38429445e-18 1.524654585e-18 6.438424056e-19) OK.
Max cell openness = 6.017067417e-16 OK.
Max aspect ratio = 614.8061099 OK.
Minumum face area = 6.778323149e-06. Maximum face area = 1.570952427. Face area magnitudes OK.
Min volume = 3.882624446e-06. Max volume = 0.8998417694. Total volume = 210.0252865. Cell volumes OK.
Mesh non-orthogonality Max: 15.19406969 average: 5.646290018
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 0.6821213047 OK.
Coupled point location match (average 0) OK.
Mesh OK.
End
I have just changed my BC, but results are very similar.
Do you know if OF uses first order or second order accuracy for pressure (as standard?)
Thank you
Julio
Old   July 12, 2013, 09:04
Julio Silveira
this is my new file if you could have a look
https://www.dropbox.com/s/3b5bjf8itswvyys/newBC.tar.gz
Thank you again
Old   July 12, 2013, 10:58
Aurelien Thinat
The default scheme for grad(p) is specified in the fvScheme file :
gradSchemes
default Gauss linear;
With your mesh you can use higher order schemes :
1) Gauss linear corrected schemes in laplacians instead of :
laplacianSchemes
default Gauss linear limited 0.333;
2) corrected in SnGrad instead of :
snGradSchemes
default limited 0.333;
Old   July 12, 2013, 18:10
reza sadeghi
reza1111 is on a distinguished road
Hi forum,
I am new in OF. and for being familiar with OF I tried to simulate a flow around NACA0009 at AOA of 5 degree and Re=800000. I'm going to validte my result with data in below link:
http://library.propdesigner.co.uk/ht...teristics.html
so the NACA0009 Cl at AOA of 5 should be about 0.57
in some trial with fluent I got CL=0.49, which is good for my first attempt.
so I simuluted the flow with simpleFoam solver, I used airfoil2D test case and I changed Mesh, B.C, fluid property and initial values. I tried to set my case accurately, but I am completely confused why the CL becomes about 0.016!!!
I compared the friction and pressur force between OF and fluent result the ratio was 1:25.!!!
I am sure that I am making a mistake in OF simulation. but I can't find it.
thanks alot for attention,
Reza
reza1111 is offline   Reply With Quote
Old   July 15, 2013, 03:48
reza sadeghi
I checked my run setup accurately, but the result was disappointing.
any idea please?
Old   July 15, 2013, 06:37
Julio Silveira
any idea please?
you are getting completely wrong results due to the vectors your are using to calculate Cl and Cd.
In your controldict you need to change:
liftDir (0 1 0);
dragDir (1 0 0);
To the angle off attack you are simulating.
E.g for aoa =4 degress
liftDir (0.05233 0.99863 0)
dragDir (0.99863 0.05233 0)
Also make sure you Area reference and Are length is the same as the one you are comparing to.
Hope it helps
Julio
Old   July 15, 2013, 07:21
reza sadeghi
Hi Julio
As you see in my mesh I changed the airfoil angle to 5 degree instead of changing the inlet flow angle so I set:
liftDir (0 1 0);
dragDir (1 0 0);
In my first runs I thought the wrong result is because of changing the density of fluid, so I tried to run my case with density=1, no change happened in results.
In literature the area reference is the length of chord. so I did.
Thanks alot,
Reza.
Old   July 15, 2013, 09:31
Julio Silveira
Thank you for your help, but I still get the same results. Nothing major changed :-(
OpenFOAM vs. Fluent & CFX marco FLUENT 16 November 17, 2020 04:53
OpenFoam to Fluent data conversion Problem vemps OpenFOAM 1 August 8, 2011 02:30
Fluent elbow in Openfoam chemeng OpenFOAM 1 January 21, 2010 03:52
OpenFOAM vs. Fluent & CFX marco Main CFD Forum 81 March 31, 2009 14:22
OpenFOAM vs Fluent for cylinder at Re%3d150 lr103476 OpenFOAM Running, Solving & CFD 40 December 18, 2008 09:09
