Home > Forums > OpenFOAM Running, Solving & CFD
Temperature dependent Cp: JANAF tables vs Debye model
Old   July 12, 2013, 10:40
Default Temperature dependent Cp: JANAF tables vs Debye model
antb is on a distinguished road
I'm working with an expanding gas from a high pressure to a low pressure cavity. With this expansion comes an extreme cooling of the gas to sub 50 K temps from an initial 300 K (Joule-Thomson effect). I am using for this the rhoCentralFoam solver.
Now I remember reading somewhere that solvers start experiencing problems at very low temperatures, though there didn't seem to be any clear stated reasons as to why. One area I can imagine where there may be a problem is the constant Cp (specific heat) characteristic from most thermophysical models.
To help with this, I know there are JANAF tables to specify a temperature dependant Cp. These tables however usually go from values like 200K to 6000K, while we know that Cp starts to drop dramatically at low temps (<< 200K), although this is substance dependent. Therefore, JANAF tables aren't really of a any use. What I want to know, is how to use a Debye model (http://en.wikipedia.org/wiki/Debye_model), which seems to be perfect at modeling low temps Cp. One way I could imagine going about this is fitting the JANAF polynomial onto the Debye curve, but this seems a bit backward.
If I am not required to play with the Cp value and there exists a simpler method for making simulations more stable at very low temp, please let me know.
antb is offline   Reply With Quote
Old   August 26, 2013, 16:57
immortality's Avatar
Ehsan
immortality is on a distinguished road
In thermodynamics and solid state physics, the Debye model is a method developed by Peter Debye in 1912 for estimating the phonon contribution to the specific heat (heat capacity) in a solid
Hi
it seems Debye be related to solids,are you sure it can be used for gases?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Thread Tools
Trackbacks are On
Newer Janaf Model iyer.arvind OpenFOAM 41 April 7, 2016 10:32
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
Time Dependent Temperature Dependent BC Analysis RP Main CFD Forum 1 March 28, 2008 02:22
FIDAP and temperature dependent mat properties semetay FLUENT 0 July 11, 2006 13:45
Boussinesq model reference temperature? David Agostinho Main CFD Forum 0 June 23, 2004 10:53
