Home > Forums > OpenFOAM Running, Solving & CFD
BC's for non-matching faces
Like Tree2Likes
  • 1 Post By yzf1215
  • 1 Post By Mojtaba.a
Old   July 17, 2013, 13:17
Default BC's for non-matching faces
Felipe Portela
fportela is on a distinguished road
Hello all,
I am trying to run a case where I need to use periodic boundary conditions (inlet/outlet) but unfortunately the mesh is not the same on both patches, i.e., the geometry is the same, but one patch has fewer faces than the other.
Is there any way to achieve this? I thought about using cyclicAMI but haven't managed to get it working...
Cheers,
Felipe
fportela is offline   Reply With Quote
Old   July 20, 2013, 08:18
Zifei Yin
yzf1215 is on a distinguished road
I suppose cyclic boundaries in OpenFOAM needs same amount of nodes and you shoud set the tolerance for matching the corresponding nodes.
fportela likes this.
yzf1215 is offline   Reply With Quote
Old   July 21, 2013, 20:29
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
It would be easy to make matching faces in GAMBIT or ICEM, why not trying these instead?
Learn OpenFOAM in Persian for free, And ask your questions here.
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   July 22, 2013, 04:12
Felipe Portela
Hey,
Thanks for the replies.
Indeed, cyclic conditions require the same amount of nodes/faces and the meshes should not be very different on both patches, so this will not work for me.
Regarding GAMBIT or ICEM, not only don't I have a license for those, but I have no experience with them... The geometry I am trying to mesh involves sharp corners and I have already had trouble getting a proper mesh in Gmsh.
Maybe I can rephrase the question: is it possible to map two patches to each other, so that the solution is interpolated from one to the other?
Thread Tools
Trackbacks are On
No layers in a small gap bobburnquist OpenFOAM Native Meshers: snappyHexMesh and Others 6 August 26, 2015 09:38
Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Native Meshers: snappyHexMesh and Others 8 September 13, 2012 09:28
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 1 June 7, 2012 13:39
snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Native Meshers: snappyHexMesh and Others 2 March 27, 2011 21:11
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 20:43
