icoDyMFoam - sclar transport with adaptive mesh refinement
Like Tree2Likes
  • 1 Post By yhaomin2007
Old   May 28, 2011, 18:41
Default icoDyMFoam - sclar transport with adaptive mesh refinement
Dr. Alexander Vakhrushev
makaveli_lcf is on a distinguished road
Send a message via ICQ to makaveli_lcf
Please check http://openfoamwiki.net/index.php/Contrib_icoDyMFoam,
here I submitted a small example (todays between-coffees-made solver)
how to use dynamicRefineFvMesh class in generic applications.
Thanks to developers for such hard work) Your years of designing - our "one click" lines in solver))) Thanks once more!
Best regards,
Dr. Alexander VAKHRUSHEV
Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics"
Simulation and Modelling of Metallurgical Processes
Department of Metallurgy
University of Leoben
http://smmp.unileoben.ac.at
makaveli_lcf is offline   Reply With Quote
Old   July 3, 2011, 15:21
FlinkFingerFlo. is an unknown quantity at this point
Hi makaveli_lcf,
hi foamers,
based on your example and Anne Kösters example I try to build a solver using the residuum to refine the mesh... but I can't get it running
Thanks,
FlinkFingerFlo.
FlinkFingerFlo. is offline   Reply With Quote
Old   July 17, 2013, 15:05
Haomin Yuan
yhaomin2007 is on a distinguished road
I read your solver code, it seems that after mesh.update, you directly goes into U equation and p equation. I also tried this on my solver for steady state.
There is error information like this :
--> FOAM FATAL ERROR:
field does not correspond to level 0 sizes: field = 115185 level = 112000
I looked into the mesh, it seems mesh.update refined the mesh, but when it goes to solve equations, there is an inconsistent. Do you think if there is any additional setting I should do?~
thank you.
yhaomin2007 is offline   Reply With Quote
Old   July 17, 2013, 18:25
there already some standard solvers in OF 2.2.1, please check them, they are more consistent than mine)))
Best regards,
Old   July 17, 2013, 21:28
Haomin Yuan
Hi, Alex
I think I found out the problem, I should "cacheAgglomeration off;" in fvSolutions file.
But I met a another problem, when it dynamic refine the mesh, it always produce some triangle cells. This also happens in your example case.
I have seen some papers talking about adaptive mesh refinement in OpenFOAM, they can make every cell hexagon. Do you know how to do that in settings?
thank you in advance~
Old   July 18, 2013, 02:25
first you are totally right about aglomeration caching:
1. it should be switched off when doing dynamic refinement
2. no triangles are produced! it is just a postprocessing issue in paraview. Switch on "Use VTKPolyhedron" in Object Inspector. It is because your refined hex becomes a polyhedron, despite it looks still like a hex)))) In paraview it is splitted into pyramids giving you triangles. Please check here https://sites.google.com/site/smmp01...r-a-vakhrushev in Galery my first animation, it is done "properly")))
3. There was some issues (I think I was using OF 1.7) with tet cells: poly cells were excluded from refinement, but tet cells were not! I just patch dynamicRefine lib a little bit to avoid that, bevcause by engeneering geometries has sometimes tet cells... But all in all dynamic refinement is doing actually pure hex refinement
Cheers,
Alex
Best regards,
Old   July 18, 2013, 10:24
Haomin Yuan
Hi, Alex,
thank you for your reply. I think you are right, OpenFOAM did not split those cells. It is just problem of paraview. But I have another question, in my research there is some pentahedral cells. Because I am simulating a axisymmetric geometry. Is there a way to tell OpenFOAM to just refine those hexagon cells, and ignore those pentahedral cells?
thank you.
Old   July 18, 2013, 10:34
I think it is already there... It is refining hex only... Look at the dynamicRefineFvMesh.C:
00951     // Set cells that should not be refined.
00952     // This is currently any cell which does not have 8 anchor points or
00953     // uses any face which does not have 4 anchor points.
00954     // Note: do not use cellPoint addressing
00955
00956     // Count number of points <= cellLevel
00957     // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
00958
00959     labelList nAnchors(nCells(), 0);
00960
00961     label nProtected = 0;
00962
00963     forAll(pointCells(), pointI)
00964     {
00965         const labelList& pCells = pointCells()[pointI];
00966
00967         forAll(pCells, i)
00968         {
00969             label cellI = pCells[i];
00970
00971             if (!protectedCell_.get(cellI))
00972             {
00973                 if (pointLevel[pointI] <= cellLevel[cellI])
00974                 {
00975                     nAnchors[cellI]++;
00976
00977                     if (nAnchors[cellI] > 8)
00978                     {
00979                         protectedCell_.set(cellI, 1);
00980                         nProtected++;
00981                     }
00982                 }
00983             }
00984         }
00985     }
00986
Here they check for none hex cells...
Best regards,
Old   July 18, 2013, 10:49
Haomin Yuan
Yes, you are right, it checked whether the anchor points of this cell. But it only protected the cell whose anchor point number is larger than 8. It will not protect those cells with less than 8 anchor points.
For my case, there are pentahedral cells. The error message is this:
cell 5129 of level 0 does not seem to have 8 points of equal or lower level
cellPoints:6(12234 12235 13288 13289 12284 12285)
pointLevels:6{0}
From function hexRef8::setRefinement(const labelList&, polyTopoChange&)
in file polyTopoChange/polyTopoChange/hexRef8.C at line 3527.
FOAM aborting
I think I should change
if (nAnchors[cellI] > 8) to if( (nAnchors[cellI] > 8)||(nAnchors[cellI] < 8))
to make sure it only refine those hexagon cells.
makaveli_lcf likes this.
Old   July 18, 2013, 10:50
Yep! Right direction! Just build a new library for dynamicMeshRefine
Best regards,
Old   July 18, 2013, 10:51
For tet it didn't work as well, so I modified that condition
Best regards,
Old   July 18, 2013, 10:53
Haomin Yuan
I will try this.
Thank you very much~
Old   July 18, 2013, 15:21
Haomin Yuan
Hey,
I think I have figured out how to do that, I will post my code here if other people are interested. We have to judge whether this cell is hex or not. But we cannot just
change "if (nAnchors[cellI] > 8)" to "if( (nAnchors[cellI] > 8)||(nAnchors[cellI] < 8))"
because the anchor number of this cell (nAnchors) is not completely calculated after this whole loop. So we have make a judgement after this loop.
forAll(pCells, i)
if (pointLevel[pointI] <= cellLevel[cellI]) l
nAnchors[cellI]++;
//if (nAnchors[cellI] > 8)
// protectedCell_.set(cellI, 1);
// nProtected++;
for(label cellI = 0; cellI < nCells() ; cellI++) // after nAnchors[cellI] is complete caculated, determine whether it should be protect or not. Only hex cells are not protected.
if ((nAnchors[cellI] > 8)||(nAnchors[cellI] < 8))
nProtected++;
Now, only hex cells are not protected, other non-hex cell are all in protection, and will not cause fatal error.
I hope this will be useful to somebody.
Old   July 19, 2013, 11:38
Great job, this issue was also there, I can remember!
Best regards,
adaptive meshing clifford bradford Main CFD Forum 14 September 3, 2022 19:13
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Problems scaling down the mesh of a stirred tank (GGI, icoDyMFoam) Tobb OpenFOAM 2 February 7, 2013 13:06
Searching criteria for adaptive mesh refinement Flowee ANSYS Meshing & Geometry 1 August 6, 2010 12:43
