externalWallHeatFluxTemperature in turbulence models
Old   June 27, 2012, 06:40
Default externalWallHeatFluxTemperature in turbulence models
irw
irw is on a distinguished road
I wish to apply a nonuniform heat-transfer-coefficient boundary coefficient to a wall. I have used the following boundary condition for temperature:
my-boundary
type externalWallHeatFluxTemperature;
K basicThermo;
KName none;
Ta 300;
value 300;
gradient 0;
h nonuniform List<scalar>
If I specify 'h' with units [W/m2/K] I get far too much heat leaving the boundary.
I'm having trouble following the units through externalWallHeatFluxTemperatureFvPatchScalarField. C
00210 q = (Ta_ - *this)*h_;
I think this implies [q] = [K - K]*[W/m2/K] = [W/m2].
Then...
00224 if (q[i] > 0) //in
00225 {
00226 this->refGrad()[i] = q[i]/K(*this)()[i];
00227 this->refValue()[i] = 0.0;
00228 this->valueFraction()[i] = 0.0;
00229 }
00230 else //out
00231 {
00232 this->refGrad()[i] = 0.0;
00233 this->refValue()[i] = KDelta[i]*q[i] + patchInternalField()()[i];00234 this->valueFraction()[i] = 1.0;
00235 }
For the heat input case, I see [refGrad]=[W/m2] / [W/m/K] = [K/m], which is good.
For the heat output case, I think the units of kDelta are [W/m/K]*[1/m]=[W/m2/K] based on mesh.surfaceInterpolation.c and
00202 scalarField KDelta(K(*this)*patch().deltaCoeffs());
Doesn't this imply the units of refValue are [refValue] = [W/m2/K] * [W/m/K] + [K] ?
Is this a bug or have I mis-understood something?
Thanks,
irw
irw is offline   Reply With Quote
Old   July 20, 2013, 05:29
sebastian n
gruenertee is on a distinguished road
Hi foamers,
first i want to say that i am interested in getting the problem solved from the first post "If I specify 'h' with units [W/m2/K] I get far too much heat leaving the boundary" too. Can anyone explain the question from the first post?
My question deals with the problem how to read out data for Ta from a .dat file; is it in general possible?
K solidThermo; // solidThermo or lookup
q uniform 1000; // Heat flux / [W/m2]
Ta uniform 300.0; // Tambient temperature /[K]
h uniform 10.0; // Heat transfer coeff /[W/Km2]
value uniform 300.0; // Initial temperature / [K]
KName none;
Can i combine this type with:
type uniformFixedValue;
uniformValue tableFile;
tableFileCoeffs
fileName "inlet.dat";
outOfBounds warn;
Thank you very much!
gruenertee is offline   Reply With Quote
different zones, different turbulence models gmwsy FLUENT 5 June 17, 2020 15:42
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 10:26
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
Tutorial 21: Turbulence models spatialtime CFX 4 April 24, 2009 05:25
Turbulence models for GCV method dosen't work! Sima Baheri Phoenics 0 January 6, 2007 04:08
