Continuity error with volume flow split boundary condition
I am trying to simulate a case in which a tube with one inlet bifurcates in two outlets. I ran the case with simpleFoam solver by fixing volume flow rate at all outlets(because that is the condition to be satisfied) and got following errors: --> FOAM FATAL ERROR: Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Total flux : 0.000719163 Specified mass inflow : 0.000400984 Specified mass outflow : 0.000400984 Adjustable mass outflow : 0 From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p in file cfdTools/general/adjustPhi/adjustPhi.C at line 118. FOAM exiting I ran potentialFoam and used the generated velocity field to run simulation and again encountered same error. I don't understand when inflow rate is equal to outflow rate then why OpenFoam is giving continuity errors. Any suggestions on solving this problem? Thanks, Mayank |
Greetings Mayank,
What is the boundary condition on the inlet you are using? I can't remember correctly what the total flux value should be, but clearly the values do not add up. The total is not equal to the inlet+outlets, therefore you're not allowing enough fluid into the domain or you are extracting too much fluid. Best regards, Bruno |
Hi Bruno,
Thanks for the quick response. The flow at the inlet is parabolic. Basically, I want to divide the inlet flow into 0.52 times at one outlet and 0.48 times at the other outlet. Below are my 0/p and 0/U files: 0/U Code:
/*--------------------------------*- C++ -*----------------------------------*\ Code:
/*--------------------------------*- C++ -*----------------------------------*\ Mayank |
Hi Mayank,
What values do you get if you do not constrain the outlets to a fixed value? And did you know that simply by defining a parabolic shaped inlet, it does not strictly mean that the mass-flow you were calculating for, is properly respected? Because the parabolic profile values will be placed inside discrete cells, for which the total mass-flow sum might not be exactly the same as the parabolic profile... here's an similar example of what I mean: http://ars.els-cdn.com/content/image...003428-gr1.gif And then there's the really annoying part... OpenFOAM can be veeeery picky with errors of up to 1e-6 or something like that... so, even if it shows that the the values are virtually identical, they are probably not computationally identical :( I vaguely remember seeing on this forum some discussions about splitting flow between patches... but I can't remember what it talked about in specific :( Best regards, Bruno |
Ok, so this means I have to somehow access total volume flow rate field (say phi_inlet) at the inlet patch from within the simulation and define volume flow rate at outlet1=0.52*phi_inlet and outlet2=0.48*phi_inlet .....that can be done using swak4Foam.....I did that but it didn't work either.....it still gave errors.....
Below is 0/U file for what I have said: Code:
/*--------------------------------*- C++ -*----------------------------------*\ Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model laminar No field sources present SIMPLE: convergence criteria field p tolerance 1e-05 field U tolerance 1e-05 field nuTilda tolerance 1e-05 Starting time loop Time = 0.005 swak4Foam: Allocating new repository for sampledGlobalVariables smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0952526, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0542153, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.060015, No Iterations 3 --> FOAM FATAL ERROR: Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Total flux : 0.000360325 Specified mass inflow : 0.000400984 Specified mass outflow : 0 Adjustable mass outflow : 0 From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p in file cfdTools/general/adjustPhi/adjustPhi.C at line 118. FOAM exiting When I ran potentialFoam and then used the velocity field for new simulation. I got the same error but with different values: --> FOAM FATAL ERROR: Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Total flux : 0.0147875 Specified mass inflow : 0.000801967 Specified mass outflow : 0 Adjustable mass outflow : 0 From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p in file cfdTools/general/adjustPhi/adjustPhi.C at line 118. |
Is there any way I can reduce the tolerance for continuity errors in OpenFOAM?
Regards, Mayank |
Hi Mayank,
I see that you continued working on this and that the latest thread related to this topic is this one: http://www.cfd-online.com/Forums/ope...ting-b-cs.html Unfortunately I don't have the time to look further into this, specially since it looks like it'll require some heavy duty work. Nonetheless, regarding the last question you made: I haven't found where the setting for the mass flow balance is configurable. :( Good luck! Best regards, Bruno |
Thanks Bruno for your concern but the problem is now solved. Thanks to the forum.
Regards, Mayank. |
Hi Mayank,
How did you solve it? Thanks, Hrushi |
I didn't set velocity boundary conditions at all patches. One usually runs into trouble with stupid "continuity errors". The tolerance for continuity error is 10e-8 (refer source code for adjustPhi.C). You should define pressure boundary condition on atleast one patch then everything goes fine.
Do not use the expression "sum(phi)" for setting massflow/volumeflow boundary conditions conditions with swak4FOAM or any other place because at t=0 there is no field as "phi" ,although velocity and pressure fields exist, hence OpenFOAM returns a zero value and continuity errors start showing up. Regards, Mayank. |
Continuity error in sloshingtank2d
I get continuity errors in sloshingtank2D -- no inlets or outlets, which is strange.The error message is as follows: [0] --> FOAM FATAL ERROR: [0] Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Total flux : 5.50768e-18 Specified mass inflow : 1.0222e-17 Specified mass outflow : 4.16554e-17 Adjustable mass outflow : 0 [0] [0] [0] From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p [0] in file cfdTools/general/adjustPhi/adjustPhi.C at line 118. [0] FOAM parallel run exiting [0] I ckecked the adjustPhi.C code and noted the small threshold that triggers this message and causes analysis to stop. Would you have any suggestions as to what might be causing this? I have a small 2D tank -- width 1 m, height 1 m. Water depth is 0.4 m. I am applying discrete oscillations in the range of 0.0002 to 0.006 m. However, the displacements are not in the form of a list, but rather computed by another program and then sent to OpenFoam for computing pressures on the tank walls. So for example, a time time t=0, the displacements are 0; then at time =0.02, the displacement may be 0.003, so OpenFoam will be asked to return the pressure values for the following range: time displacement 0 0 0.02 0.003 and so on. At each call to OpenFoam, a pair of start/stop time and associated displacement will be sent to OpenFoam. So OpenFoam will be starting and stopping as the program that generates these displacements runs. I realize that the coupling is not an issue, but just thought it may be helpful to give a brief background on the circumstance under which OpenFoam is being run. Thankyou. I look forward to your reply -- or that of anyone in the Forum who might come across this post. |
Sorry for the false alarm. I was generating displacement in the x axis which in the case of the 2D tank, does not have any dimension. In the 2D case there can only be movement in the Y and Z direction, and I was trying to push the tank in the +-X direction.
