-   -   Formulation in FSI problem with pimpleDyMFoam (http://www.cfd-online.com/Forums/openfoam-solving/121136-formulation-fsi-problem-pimpledymfoam.html)
NewOrleans July 22, 2013 13:01
Hi Foamers,
I am working in a 2D model of a FSI problem considering a rigid body suspended from a spring. The idea is that the body will experiment VIV.
I would like to know what is openFoam doing when it solves this problem (I am using pimpleDyMFoam).
I mean, is it a weakly coupled interaction case? The fluid problem is solved based in the ALE formulation? How does openFoam solve the vibration problem?
I would appreciate of you letting me know where I can find this information.
Thank you
bskywalker October 16, 2014 12:33
Hi NewOrleans,
I'm experiencing the same difficulties as you. Have you find these informations in the meantime? If not, is there anyone who can help us?
Thanks.
Svensen May 13, 2015 06:24
The same question...
Harak May 14, 2015 18:44
Originally Posted by NewOrleans (Post 441292)
Hi Foamers,
Thank you
Correct me if I'm wrong but as far as I know the pimpleDyMFoam solver is not a FSI solver. Instead, it is just the pimpleFoam solver allowing additional dynamic mesh.
Or how did you set up your case to make FSI possible?
