[interFoam] pipe flow - phase piling up at outletpatch ?! |
October 6, 2014, 17:41 |
Rep Power: 12 |
I need to simulate a turbulent twoPhase pipe flow. The is set up with interFoam. It works fine until the liquid phase hits the outlet-patch - then the pipe will fill up. No "drop" of the liquid Phase passes the boundarypatch. I know that it has to be a problem with the bc ...I tried several bc inletOutlet, pressureInlet ...but I cant figure out a way that will bring both phase through the patch. https://www.wuala.com/awarth/Cloudbe...y=95tBfztyiTiN It would be great if anyone could give a glance at this....Im somehow puzzeld. best regards Alex |
boundary condition, interfoam, outlet, two phase |
Display Modes | |
Gravity/Buoyancy/Buoyancy reference density in two phase flow | sharifi | CFX | 10 | June 9, 2014 11:23 |
two-phase flow with a single phase simulation | caunima | Fluent Multiphase | 0 | October 28, 2013 03:42 |
gas-liquid 2 phase flow in microchannels using VoF | LyngHoo | FLUENT | 1 | November 13, 2012 20:01 |
pulsating static pressure around zero at pipe flow | David Kim | FLUENT | 0 | May 16, 2006 14:47 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 2, 2003 00:32 |
