pipeCyclic (60°) - AMI weights go down to 0
1 Attachment(s)
I am having issues with cyclicAMI boundaries. My case: I took the pipeCyclic case, and made the following changes: - a geometry of 60° instead of 90° - a mesh generated with snappyHexMesh I also added a createPatchDict to generate the AMIs. The mesh I get is OK (checkMesh gives OK, and the two AMIs don't seem to have any non-overlap regions), but after running createPatch I still get weights that go down to zero. I first thought the problem was the createPatchDict, but when I try it on the original pipeCyclic case it works just fine. Also, the same setup for a 90° geometry (only changing the stl files in triSurface) works perfectly (all weights =1). I attached my case here (with an Allrun script) and I would be grateful if anyone has any idea about where the problem might come from. EDIT: this was apparently a bug, fixed in the latest 2.2x version http://www.openfoam.org/mantisbt/view.php?id=937 |
