Do the cell IDs of a domain change on the fly?
Like Tree1Likes
  • 1 Post By romant
Old   August 14, 2013, 04:26
Default Do the cell IDs of a domain change on the fly?
Canakkale Dardanelspor
HakikiCanakkaleli is on a distinguished road
Hi
== 1 ==
As the title indicates, I wonder whether the cell IDs of a computational domain do change or not while an OpenFOAM case is running on a single processor?
== 2 ==
* on multiple processors whilst a parallel job is executed?
Many thanks for your help.
HakikiCanakkaleli is offline   Reply With Quote
Old   August 15, 2013, 04:38
romant's Avatar
Roman Thiele
romant is on a distinguished road
They should not change while the case is running, as they are the ID's which you can read in the different file you see in constant/polymesh.
The ID of each cell/point/face ... is the line number which you can count from the beginning of each of these field, for example this face file
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       faceList;
    location    "constant/polyMesh";
    object      faces;
268989
4(1 9 73 65)  // ID 1
4(8 72 73 9)  // ID 2
4(64 65 73 72) // ID 3
4(0 64 72 8)    // ID 4
HakikiCanakkaleli likes this.
~roman
romant is offline   Reply With Quote
Old   August 15, 2013, 04:59
My personal experience suggests that:
== 1 ==
Once a case starts running -on a single processor or on many processors-, the cell IDs remain the same whilst constant/polyMesh files do not change. So, the cell IDs do not change on the fly.
== 2 ==
However, when a computational domain is decomposed by decomposePar, the cell IDs are no longer the same with the case executed by a single processor. Namely, each processor re-numbers the cells that it contains starting from 0.
Many thanks.
== 3 ==
But all these arise a new issue to me.
Is there any parameter -like cell coordinate, cell ID or whatsoever-, that I can flag a certain cell no matter what happens -like decomposing the computational domain or rotating region?
More precisely, is there any parameter that remains the same for cells no matter what happens so that I can easily identify this/these particular cell/cells?
Old   August 15, 2013, 05:00
Elvis
elvis will become famous soon enough
you can use the command
renumberMesh
the command Renumbers the cell list in order to reduce the bandwidth, reading and renumbering all fields from all the time directories
http://www.openfoam.com/features/mesh-manipulation.php
usually the IDs do not change
elvis is offline   Reply With Quote
Sliding mesh and multiple cell domain simulations Akash C SU2 Shape Design 3 January 4, 2015 03:39
convergenceof natural convection prob. in cfx cpkewat CFX 15 January 31, 2014 06:29
injection problem Mark New FLUENT 0 August 4, 2013 01:30
Help Me, what's the Cell Above any given cell in 3D. gomane8 Main CFD Forum 3 September 11, 2011 21:29
moving grid with domain size change Hu Main CFD Forum 5 May 13, 2004 21:14
