arnaud6 |
July 25, 2013 10:48 |
solver compilation problem, /bin/linux64GccDPOpt directory empty
Hello everybody, this is my first message on the forum and I hope my problem won't be too difficult to solve.
As a first step I am trying to create a new solver from an existing one "channelFoam". I have done all the steps described in the second section of http://openfoamwiki.net/index.php/How_to_add_temperature_to_icoFoam
I have copied the solver "channelFoam" and renamed it to "my_channelFoam". i am working in my user space and not in the installattion space of OpenFOAM.
The error appears when I try to run wmake to compile the new solver.
My message error is
Making dependency list for source file my_channelFoam.C
SOURCE=my_channelFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/opt/openfoam171/src/turbulenceModels -I/opt/openfoam171/src/turbulenceModels/incompressible/LES/LESModel -I/opt/openfoam171/src/turbulenceModels/LES/LESdeltas/lnInclude -I/opt/openfoam171/src/transportModels -I/opt/openfoam171/src/transportModels/incompressible/singlePhaseTransportModel -I/opt/openfoam171/src/finiteVolume/lnInclude -I/opt/openfoam171/src/sampling/lnInclude -IlnInclude -I. -I/opt/openfoam171/src/OpenFOAM/lnInclude -I/opt/openfoam171/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/my_channelFoam.o
/opt/openfoam171/src/finiteVolume/lnInclude/readPISOControls.H: In function ‘int main(int, char**)’:
/opt/openfoam171/src/finiteVolume/lnInclude/readPISOControls.H:11:10: warning: unused variable ‘transonic’ [-Wunused-variable]
/opt/openfoam171/src/finiteVolume/lnInclude/readPISOControls.H:14:9: warning: unused variable ‘nOuterCorr’ [-Wunused-variable]
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/opt/openfoam171/src/turbulenceModels -I/opt/openfoam171/src/turbulenceModels/incompressible/LES/LESModel -I/opt/openfoam171/src/turbulenceModels/LES/LESdeltas/lnInclude -I/opt/openfoam171/src/transportModels -I/opt/openfoam171/src/transportModels/incompressible/singlePhaseTransportModel -I/opt/openfoam171/src/finiteVolume/lnInclude -I/opt/openfoam171/src/sampling/lnInclude -IlnInclude -I. -I/opt/openfoam171/src/OpenFOAM/lnInclude -I/opt/openfoam171/src/OSspecific/POSIX/lnInclude -fPIC Make/linux64GccDPOpt/my_channelFoam.o -L/opt/openfoam171/lib/linux64GccDPOpt \
-lincompressibleLESModels -lincompressibleTransportModels -lfiniteVolume -lmeshTools -lOpenFOAM -liberty -ldl -lm -o /home/msc/ajc12/OpenFOAM/ajc12-1.7.1/applications/bin/linux64GccDPOpt/my_channelFoam
/usr/bin/ld: cannot find -liberty
collect2: ld returned 1 exit status
make: *** [/home/msc/ajc12/OpenFOAM/ajc12-1.7.1/applications/bin/linux64GccDPOpt/my_channelFoam] Error 1
I have seen in other related posts that the new solver should appear in the $FOAM_USER_APPBIN. If I go to this directory, I can't find anything. The /bin/linux64GccDPOpt has been created but it is empty.
I precise that I am working on a college computer so that I do not have sudo rigths. I tried to set the correct environnement variables using the "source .bashrc" but I still get the error.
From the error message in the terminal window the problem may come from a library problem but I can't solve it.
It's been some time I am working on it and I would be grateful if someone can help me.
Best regards,
Arnaud
