parallel efficiency LTSInterFoam quad cpu Opteron
Old   July 27, 2013, 00:24
Default parallel efficiency LTSInterFoam quad cpu Opteron
nico
nico7 is on a distinguished road
I have access to a quad cpu (opteron 6276, 16 cores per cpu) dell machine. I've been looking at parallel efficiency running the LTSInterFoam solver with the wigley tutorial.
First results I got is shown in the following graph; this is running the small (0.2M cells) mesh (as defined in the tutorial)
I've then refine the mesh (by refining blockmesh and surface mesh of shm); I get the following results:
Not looking that great.
Should I expect something different or similar for the kind of hardward I am using?
I've run parallel jobs using the runParallel command so no options for mpirun; anything particular that I should use?
Compilation was also basic one (with openmpi).
Thanks for reading,
Nico
nico7 is offline   Reply With Quote
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 16:49
Parallel computing quad core Prad Main CFD Forum 13 February 9, 2009 14:28
OpenFOAM 13 Intel quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 13 February 5, 2008 05:26
OpenFOAM 13 AMD quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 1 November 10, 2007 23:23
