July 31, 2013, 07:21 |
Rotating impeller with fluid inlet on it
Bayard Morales
Rep Power: 16 |
Hello, guys
I would like to know if it is possible to simulate an impeller with a fluid inlet over it. Think about a garden sprinkler (but single phase). That would be a good image of it. Any ideas or examples? I am still not very experienced with OF, still too attached to CFX/Fluent way of thinking: - can you define some point fluid mass sources or you need to define proper inlets (BC's) for each inlet? As the mass flow is low and the inlet is small, I would go for point source, but don't know if it is possible. Many thanks Bayard |
Rotating body force in fluid | dl6tud | OpenFOAM Running, Solving & CFD | 2 | October 11, 2013 03:21 |
Maintaining Static Pressure at Fluid Flow Inlet | cdevalve | FLUENT | 3 | January 14, 2012 00:11 |
How to choose the mean diameter value for dispersed fluid? | creddy_trddc | CFX | 1 | October 30, 2011 04:30 |
Fluid in a rotating cylinder | Fluid Novice | Main CFD Forum | 1 | December 17, 1998 17:25 |
