Cannot validate simple pipe flow using simpleFoam |
August 6, 2013, 05:08 |
Vishal
Rep Power: 12 |
Hi all,
I am new to OpenFOAM and I am required to validate the simple case of a flow through a pipe. The boundary conditions are U - fixedvalue at inlet, zerogradient at outlet and fixedvalue zero at walls p - zerogradient at inlet and wall, fixedvalue zero at outlet. The solution shows two peaks in pressure at the inlet corners. I am using Poiseuille's law and the pressure difference i calculate is not even close to that is shown by openfoam. I am attaching my case files here. 2D_pipe_vel_driven.zip |
August 6, 2013, 05:43 |
Laurent B
Rep Power: 16 |
For a 2d axisymmetric case you should use the WEDGE type for your mesh. Have a look to : http://www.somogyibence.hu/documents.../Cornell1.html |
August 6, 2013, 06:21 |
Vishal
Rep Power: 12 |
Why can't i just normally solve it?
August 6, 2013, 06:33 |
Vishal
Rep Power: 12 |
The results match now. Can you explain me why the normal approach doesn't work and the wedge approach works?
August 6, 2013, 07:32 |
Vishal
Rep Power: 12 |
Okay, so i understand why the problem was there. Wedge is a part of a circle and a 2D rectangle (which openfoam converts to 3D block) would represent a pipe with rectangular cross section.
There is however one more problem. I should get correct results if i make a 3D pipe of circular cross section and run the simulation. My results are not conforming with Poiseuille's Law. The mesh file is too big to upload over here. It was meshed on Fluent. 10mm dia and 100mm length. |
Pipe flow with obstacle - HELP | Min | FLUENT | 6 | January 31, 2017 14:28 |
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry | mazhar1613 | ANSYS Meshing & Geometry | 1 | January 11, 2012 23:18 |
simple pipe flow question | arkur | CFX | 1 | July 11, 2008 16:32 |
some weird results about a simple pipe flow: | Ning | FLUENT | 2 | March 11, 2007 13:23 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
