[swak4Foam] Running pimpleDyMFoam with groovyBC
Like Tree1Likes
  • 1 Post By gschaider
Old   August 15, 2013, 19:31
Default Running pimpleDyMFoam with groovyBC
lexmatt is on a distinguished road
I am attempting to use groovyBC to control dynamic mesh motion with the solver pimpleDyMFoam.
As a test case, I moved the body with a fixedValue condition on motionU and it worked great. All of the elements in the mesh moved or morphed and maintained good quality.
Then I attempted to use groovyBC and I gave it the same fixed velocity (but I had to use toPoints()) in order to get it to work.
The result is that now only the surface of the body moves and none of the mesh elements move causing that first layer of cells to skew.
I compared the two cases and noticed that when it worked the internalField for meshPhi was non-zero, while for the groovyBC case, it was zero everywhere but at the boundary I was moving.
Does anyone know what I did wrong? Is there a utility I need to run before hand. Did I implement toPoints() incorrectly?
Thanks in advance for your help!
Best,
Matt
lexmatt is offline   Reply With Quote
Old   August 16, 2013, 06:52
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Best,
Matt
Did you change it in cellMotionU AND pointMotionU? Have a look at the movingConeDistorted-example how to do this consistently
immortality likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   August 16, 2013, 15:08
Thanks Bernhard!
I was missing the cellMotionUx file.
Best,
Matt
[swak4Foam] groovyBC issue - k and epsilon sagnikmazumdar OpenFOAM Community Contributions 24 March 1, 2015 07:16
Foam Fatal IO error when running pimpledymfoam orkavic OpenFOAM Running, Solving & CFD 3 December 18, 2013 16:05
Something weird encountered when running OpenFOAM in parallel on multiple nodes xpqiu OpenFOAM Running, Solving & CFD 2 May 2, 2013 04:59
[swak4Foam] groovyBC and Eqn.setReference() benk OpenFOAM Community Contributions 3 June 2, 2011 08:49
Running PimpleDyMFoam in parallel paul b OpenFOAM Running, Solving & CFD 8 April 20, 2011 05:21
