Home > Forums > OpenFOAM Running, Solving & CFD
Difference between solvers
Old   August 17, 2013, 11:16
Default Difference between solvers
Gabriel de PInho RImoli
Grimoli is on a distinguished road
Is there any difference between chtMultiRegionSimpleFoam and chtMultiRegionFoam??
At this time im using the simplefoam,but I was figuring what implements i could get if I use the regionFoam.Any suggestions??
Grimoli is offline   Reply With Quote
Old   August 17, 2013, 15:05
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings Gabriel,
If you check the User Guide, namely the section 3.5: http://www.openfoam.org/docs/user/standard-solvers.php
You'll see these descriptions:
Originally Posted by www.openfoam.org/docs/user/standard-solvers.php
chtMultiRegionFoam
Combination of heatConductionFoam and buoyantFoam for conjugate heat transfer between a solid region and fluid region
Steady-state version of chtMultiRegionFoam
As for getting started with the chtMultiRegion*Foam solvers, my advice is to study this tutorial: http://openfoamwiki.net/index.php/Ge..._-_planeWall2D
Best regards,
Bruno
Thread Tools
Trackbacks are On
Solid Mechanics Solvers added to OpenFOAM Extend bigphil OpenFOAM Announcements from Other Sources 22 June 14, 2016 14:04
Possible turbulence modelling bug in SRF solvers otm OpenFOAM Running, Solving & CFD 3 May 29, 2012 04:03
Reaction solvers megacrout OpenFOAM 5 July 8, 2011 10:54
the effect of upwind difference hades Main CFD Forum 8 March 15, 2009 00:43
Fininte difference and Finite element Technique Mahendra Singh Mehra FLUENT 3 December 23, 2005 00:49
