Misleading low Residuals long before Steady state solution is reached! |
August 20, 2013, 06:16 |
lreflow
Hello dear Foamers,
I am doing a turbulent incompressible steady state Simulation involving a porous media using porousSimpleFoam. While my pressure Residuals drop below 1e-3 after about 1000 iterations and then oscillate slightly around 5e-4 , I have obviously not reached my steady state solution at this point as can be seen in Uplot.png where the velocities at 4 points on the surface of the porous media are plotted against the iterations. Judging by the residuals alone I would have stopped the simulations way to early. I am wondering what could cause this situation where the residuals are a very bad measure of convergence? I set a low relaxation factor for the velocity following these guidelines: http://www.kxcad.net/star-ccm/online...edFlow-09.html The realizable kepsilon model was switched on after 300 iterations. I attached my checkMeshlog my fvSolution and fvSchemes file. I have to do a parameter study and if possible I would like to reduce the necessary number of iterations before starting with it. Thanks for any help and thoughts on this. Best wishes, lreflow |
Analytic solution for 2D steady Euler equations | jojo81 | Main CFD Forum | 0 | October 15, 2012 12:05 |
outflow boundary in a steady state 1D convection diffusion eq. | hans-186 | Main CFD Forum | 2 | October 14, 2012 17:39 |
Transient Solution looks like Steady State | ljwnow | FLUENT | 0 | March 26, 2012 01:54 |
No steady state solution | Danny Tandra | Main CFD Forum | 1 | September 23, 2004 02:18 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 14:37 |
