using rotatingWallVelocity in openfoam
i have made a case using rotatingWallVelocity it is running wellbut after some time i wish to stop the rotation.My boundary conditions are as follows.
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { wall { type fixedValue; value uniform (0 0 0); } inner_rotating_wall { type rotatingWallVelocity; origin (0 0 0); axis (0 0 1); omega 400; } outlet1 { type fixedValue; value uniform (0 0 0); } inlet1 { type fluxCorrectedVelocity; value uniform (0 0 0); } inlet2 { type fluxCorrectedVelocity; value uniform (0 0 0); } defaultFaces { type empty; } } // ************************************************** *********************** // I am not able to stop the rotation since in the later time directories my boundary automatically changes to inner_rotating_wall { type calculated; value uniform (0 0 0); } Will changing the 0 time directory boundary condition will do the job ???? |
