problem with cyclicAMI periodic boundaries inside MRF zone |
August 14, 2014, 13:42 |
Ash Sechler
Rep Power: 12 |
Hi All,
I am trying to simulate a wind turbine blade inside a 60 degree periodic wedge with cyclicAMI boundaries. The problem is that, even though I am including those boundaries in "nonRotatingPatches" in fvOptions, the MRF zone influences the pressure and velocity of the fluid at the boundaries. Does anyone have a clue why this is happening? I have looked at similar posts on the forum without any progress, and being able to run snappyHexMesh in parallel would save a lot of time. Thanks for taking the time to read this! Ash case: https://www.dropbox.com/s/8muroalthy...iamond_ami.zip images: https://www.dropbox.com/s/y2x7t9tg9k...2014_07_25.png https://www.dropbox.com/s/odqt3nes3k...2014_08_18.png https://www.dropbox.com/s/b0v4e0ms1c...2014_09_53.png |
August 24, 2014, 12:51 |
Ash Sechler
Rep Power: 12 |
Does anyone have any insight?
The mrf zone behaves like a rotating solid only on the ami boundaries. Everything works perfectly with regular cyclic boundaries. There doesnt seem to be any problems with the mesh. Let me know if i should give any more info. Thanks for your attention Ash |
September 28, 2014, 15:44 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Ash,
I've had this thread of yours on my to-do list for some time now and I finally managed today to have a look into this. From what I can figure out, you have this in your "system/fvOptions" file: Code:
MRF1 { type MRFSource; active yes; selectionMode cellZone; cellZone MRFZone; nonRotatingPatches (cyc0 cyc1); MRFSourceCoeffs { origin (0 0 0); axis (1 0 0); omega -0.056744;//10mph wind, tsr=2.09 } } Code:
find $FOAM_TUTORIALS -name fvOptions | xargs grep -sl nonRotatingPatches Code:
MRF1 { type MRFSource; active yes; selectionMode cellZone; cellZone rotor; MRFSourceCoeffs { // Fixed patches (by default they 'move' with the MRF zone) nonRotatingPatches (); origin (0 0 0); axis (0 0 1); omega constant 1047.2; } } If you haven't spotted it yet, unfortunately you placed the entry in the wrong block of settings. It's meant to be inside the "MRFSourceCoeffs" block. Best regards, Bruno
November 9, 2014, 10:08 |
Rep Power: 12 |
Hello!
I observed a similiar problem and none of the threads here could help me. I simulate the flow around a blade within a cylindrical 120°-domain using MRFSimpleFoam and cyclicAMI bc's with OpenFOAM 2.1. Then, I had a look at the velocity-distribution "U" in paraFoam and noticed that the direction of U at the cyclicAMI boundaries does not make any sense: The U_y-values are obviously in opposing directions (but the U-magnitude-values seem to be correct!!). Please have a look at the pictures (only the periodic faces are visible): https://www.dropbox.com/s/sm2ipqgnij...U_mag.png?dl=0 https://www.dropbox.com/s/694sboys6cesjjl/U_y.png?dl=0 The same problem occurs by using "cyclic"-bcs. Some information regarding the setup:
Does someone have a clue what might be the problem? Do I have to invert the faces somehow e.g. in topoSetDict-file?? Or is it just an "error in my logic"? Kind Regards, Stefan Last edited by overdrive; November 11, 2014 at 05:04. |
November 9, 2014, 10:39 |
Bruno Santos
Rep Power: 128 |
Quick answer:
November 10, 2014, 03:49 |
Rep Power: 12 |
Thanks for your quick answer, Bruno! Sry about the pictures/missing files:
constant/MRFZones Code:
FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object MRFZones; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 1 ( RotatingZone { //patches();// Fixed patches (by default they 'move' with the MRF zone) nonRotatingPatches (INLET OUTLET SHROUD HUB PERI1 periodic_sh); origin (0 0 0); axis (0 0 1); omega constant -1.7647; } ) // ************************************************************************* // Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application MRFSimpleFoam; startFrom startTime; startTime 0; stopAt endTime;//endTime; //writeNow endTime 5000; deltaT 1; writeControl timeStep; writeInterval 150; purgeWrite 2; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; // ************************************************************************* // Code:
FoamFile { version 2.0; format ascii; class dictionary; object topoSetDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // actions ( { name RotatingSet; type cellSet; action new; / source boxToCell; sourceInfo { box (-100000 -100000 -100000) (1000000 1000000 100000); } } { name RotatingZone; type cellZoneSet; action new; source setToCellZone; sourceInfo { set RotatingSet; } } ); // ************************************************************************* // Code:
FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { INLET { type fixedValue; value uniform (0 0 3.0); } OUTLET { type zeroGradient; } SHROUD { type slip; } HUB { type slip; } PERI1 { type cyclicAMI; } periodic_sh { type cyclicAMI; } BLADE { type fixedValue; value uniform (0 0 0); } } // ************************************************************************* // Code:
FoamFile { version 2.0; format ascii; class polyBoundaryMesh; location "constant/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 7 ( INLET { type patch; nFaces 13321; startFace 5170598; } OUTLET { type patch; nFaces 13321; startFace 5183919; } PERI1 { type cyclicAMI; nFaces 18684; startFace 5197240; matchTolerance 0.0001; neighbourPatch periodic_sh; transform rotational; rotationAxis (0 0 1); rotationCentre (0 0 0); } periodic_sh { type cyclicAMI; nFaces 18684; startFace 5215924; matchTolerance 0.0001; neighbourPatch PERI1; transform rotational; rotationAxis (0 0 1); rotationCentre (0 0 0); } SHROUD { type wall; nFaces 10864; startFace 5234608; } HUB { type wall; nFaces 9690; startFace 5245472; } BLADE { type wall; nFaces 12836; startFace 5255162; } ) // ************************************************************************* // Last edited by wyldckat; November 17, 2014 at 15:24. Reason: Added [CODE][/CODE] |
November 17, 2014, 15:34 |
Bruno Santos
Rep Power: 128 |
Hi Stefan,
I finally managed to give a look into this. I suspect that it might be due to the exact minor version of OpenFOAM 2.1 you're using. In other words, you might be using a version that has a bug that has already been fixed in newer versions. Do you know which exact version you're using of OpenFOAM? Is it one of these?
Bruno |
November 18, 2014, 05:53 |
Rep Power: 12 |
OpenFoam 2.1x12.3 (2.1-c1330db6b6e8) for Linux Suse 12.3
Actually, I am not sure if it is really a bug now. I computed the U_x and U_y values in a certain cell of PERI1 and in the corresponding one of periodic_sh. Then, I computed the normal component of these vectors and found out that the U-direction seem to be okay. But I am not really sure about this explanation attempt.... Kind regards, Stefan |
November 23, 2014, 15:39 |
#9 |
Bruno Santos
Rep Power: 128 |
Hi Stefan,
Indeed, that commit refers to one of the few last commits in 2.1.x. Unfortunately these past months I haven't had enough free time to set-up example cases to check situations like these myself. The initial images you provided do give a strange notion that something wrong is going on. If you could provide/share a simple example case that reproduces this problem, I or anyone else could give it a try with more than one version of OpenFOAM and try to diagnose what's going on, namely if it's something that's already been fixed or not. Best regards, Bruno |
December 10, 2014, 10:11 |
#10 |
Rep Power: 12 |
Hi Bruno,
thanks for your advice. Before doing example-test-cases, let me ask one another question regarding the topoSetDict-file (maybe the reason of the problem is in here). I only defined a cellZone (cellZoneSet). Does MRFSimpleFoam need a faceZone (faceZoneSet) with the same name, too? Or is not necessary? Kind regards, Stefan |
December 13, 2014, 19:45 |
#11 | |
Bruno Santos
Rep Power: 128 |
Hi Stefan,
What is important is that the patches that are meant to be not moving should be identified accordingly. Unless there is one or more patches that you listed and that aren't part of (or within) the aforementioned cellZone. The other thing that comes to mind is that the mesh might be unsuitable for simulating with OpenFOAM, at least not without taking a few more counter-measures. Which reminds me that I forgot to ask about the mesh stats, namely the output from this command: Code:
checkMesh -allTopology -allGeometry Bruno |
December 15, 2014, 09:33 |
#12 |
Rep Power: 12 |
Hi Bruno,
I appreciate your help, thanks! I checked the MRF-Code, too, and yes, you're right (maybe faceZones might be needed in older versions). The MRF-cellZone includes the whole domain, it's the only cellZone in my case. All patches (mentioned in the boundary-file above) except of "BLADE" are non-rotating patches and are defined in constant/MRFZones. Is there another way to declare them? checkMesh-results: Code:
Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 2864496 faces: 8449612 internal faces: 8306618 cells: 2792705 boundary patches: 7 point zones: 0 face zones: 1 cell zones: 1 Overall number of cells of each type: hexahedra: 2792705 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. Face-face connectivity OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology Bounding box INLET 21164 21456 ok (non-closed singly connected) (0.908437 -27.9726 -32.3) (32.2998 27.9726 -32.3) OUTLET 21164 21456 ok (non-closed singly connected) (0.908437 -27.9726 32.3) (32.2998 27.9726 32.3) SHROUD 21697 21952 ok (non-closed singly connected) (16.15 -27.9726 -32.3) (32.2999 27.9726 32.3) HUB 17858 18224 ok (non-closed singly connected) (0.908437 -1.57346 -32.3) (1.81687 1.57346 32.3) BLADE 28255 28368 ok (non-closed singly connected) (1.61829 -0.874904 -0.293274) (8.075 0.874904 0.293278) side1 16428 16688 ok (non-closed singly connected) (0.908437 -27.9726 -32.3) (16.15 -1.57346 32.3) side2 16428 16688 ok (non-closed singly connected) (0.908437 1.57346 -32.3) (16.15 27.9726 32.3) Checking geometry... Overall domain bounding box (0.908437 -27.9726 -32.3) (32.2999 27.9726 32.3) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (2.96852e-15 -9.66145e-17 -2.90233e-16) OK. Max cell openness = 2.67082e-15 OK. Max aspect ratio = 178.188 OK. Minimum face area = 1.83031e-08. Maximum face area = 13.1418. Face area magnitudes OK. Min volume = 1.69422e-11. Max volume = 8.9323. Total volume = 70323.5. Cell volumes OK. Mesh non-orthogonality Max: 59.195 average: 18.523 Non-orthogonality check OK. Face pyramids OK. Max skewness = 1.76821 OK. Coupled point location match (average 1.06121e-09) OK. Face tets OK. Min/max edge length = 0.000122124 4.616 OK. All angles in faces OK. Face flatness (1 = flat, 0 = butterfly) : average = 0.999993 min = 0.998877 All face flatness OK. Cell determinant (wellposedness) : minimum: 1.64797e-05 average: 0.827782 ***Cells with small determinant found, number of cells: 21065 <<Writing 21065 under-determined cells to set underdeterminedCells Concave cell check OK. Failed 1 mesh checks. End https://www.dropbox.com/s/deuevzr2pg...mined.png?dl=0 I really bend over backwards with the mesh and I don't know how to avoid these elements without increasing the number of cells. Moreover, none of these elements are periodic ones. Do you think that these elements could cause problems? Kind regards, Stefan |
December 15, 2014, 14:46 |
#13 |
Bruno Santos
Rep Power: 128 |
Hi Stefan,
Those under-determined cells don't seem to be the ones responsible for the results you're seeing. I have the vague feeling of this being familiar to some bug report I saw on the bug tracker... perhaps I'm confusing with your first images I saw here on this thread. Honestly, a simplified test case is the way to go. The least number of parts/patches, the better. This way it'll be easier to assess what is the problem. Best regards, Bruno |
December 21, 2014, 18:27 |
#14 |
Dongyue Li
Rep Power: 17 |
Hello!
for my simulaions, I use AMI to deal with sliding mesh with an solver which can deal with dynamic mesh. Or, I use AMI to deal with two different mesh zones cases in which the face mesh nodes on the interface of these zones are not matched. I notice u are using MRFSimpleFoam, it can not handle dynamic mesh, so does that mean your mesh nodes are not matched? otherwise why dont u just delete the AMI patches to see the result? best, |
January 22, 2015, 01:19 |
mrf ZONE
#15 |
QuocThien
Rep Power: 13 |
When using latest Openfaom version, simulation using MRF is quite simple. You just need a cell zone, and setting in system/fvOption.
However in the old version like oF211, we need create cyclicAMI boundaries. In my simulation for windturbine, i used DOFI ( a new interface for OpenFoam). So easy! you can find detail in the case created to see how it create AMI |
January 22, 2015, 05:26 |
#16 | ||
Rep Power: 12 |
September 12, 2016, 21:57 |
#17 | |
miladrakhsha
Rep Power: 13 |
Hi Bruno, I know it has been a while since you responded to this question, but I was wondering if you could help me with my question too. I am using OpenFoam 3.0, and I have a similar problem. In my case I have AMI patches inside the moving domain as shown in the pictures. So basically I have 3 AMI patches (x2) for the 3 radial faces that connect the three 120^o domains together. I also have another one that connect the structured mesh around the airfoils to the unstructured grid. Finally I have another circular AMI patch that separates the moving cells from the stationary ones. I need the inner AMI patches since the meshes of different domain are not conforming at the interface. So what I have tried is to add only the circular patch to the nonRotatingPatches(); in the constant/MRFProperties However, the solver crashes after a few time steps. I tried to add all the AMI patches to the nonRotatingPatches() , and realized that the solver works Okay, but when I visualize the data I do not see any rotational effects in the flow field as if everything inside the domain is fixed. I am a little bit confused about the terminology here: Does fixed patches means they are fixed in GRF ? or they are the interfaces patches that are not moving with the moving domain? // Fixed patches (by default they 'move' with the MRF zone)???? I believe the mesh quality is good enough as this case ran Okay with pimpleDyMFoam, but now that I am trying MRFSimpleFoam (simpleFoam+ constant/MRFPropeties) it crashes. Screenshot 2016-09-12 20.27.41.png Screenshot 2016-09-12 20.29.21.png |
Error in solution using "Grid Interface" | agustinvo | FLUENT | 4 | January 20, 2015 12:03 |
[GAMBIT] periodic faces not matching | Aadhavan | ANSYS Meshing & Geometry | 6 | August 31, 2013 11:25 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
2D periodic problem | Markus | CFX | 0 | August 4, 2008 14:43 |
Fluent incident radiation problem | Michael Schwarz | Main CFD Forum | 0 | October 21, 1999 05:56 |
