Flow past rotating cylinder
Like Tree1Likes
  • 1 Post By sam.ho
Old   October 10, 2013, 02:15
Post Flow past rotating cylinder
sam.ho is on a distinguished road
HI Foamers
I want to set up a case of Flow past a rotating cylinder. And have some basic questions which i am not aware of...
1. Is it possible to give rotation condition to cylinder instead of stationary ? If yes How to do it ?
2. Which solver helps to solve this problem ?
Please give more info about a case set up of rotating bodies in OpenFOAM ...
sam.ho is offline   Reply With Quote
Old   October 10, 2013, 04:36
wided
wiedangel is on a distinguished road
Dear Sam.ho
You need to detail your case more in order to get some help
wiedangel is offline   Reply With Quote
Old   October 10, 2013, 04:51
Default Details of the problem
Please find the attached picture which explains my problem.
And i am reading the research paper to arrive at geometric dimensions, Boundary conditions and meshing.
I just want to know
Which solver can be used for this problem ? and how to give rotation to Cylinder during simulation ?
Old   October 10, 2013, 07:08
wided
you can use either MRFSimpleFoam or pimpleDyMFoam. Take a look at the tutorials which are using these two solvers (especially the one with the title: mixerVessel2D)
hope it helps.
Old   October 10, 2013, 07:49
Thanks a ton
wiedangel likes this.
Flow past a cylinder, Reynolds No: 100, Tracking strouhal Number. Karan FLUENT 11 November 14, 2016 04:49
Flow past a cylinder. Help needed Lurapa Main CFD Forum 1 August 18, 2013 11:25
[ICEM] Flow past a 2D cylinder arun7328 ANSYS Meshing & Geometry 0 February 15, 2013 12:17
Drag coefficient of flow past cylinder vs time pedroxramos FLUENT 0 January 14, 2013 12:39
flow below a vertical rotating cylinder hani Main CFD Forum 1 October 9, 2002 13:28
