-   -   energy equation for porousSimpleFoam (http://www.cfd-online.com/Forums/openfoam-solving/123104-energy-equation-poroussimplefoam.html)
m5m5kh September 4, 2013 10:42
Hi dear foamers
I wrote a TEqn for my solver.
the formula is something like this:(A. Bejan Convection Heat Transfer,2nd edition, pages 571,575,576)
-dp/dx = [(mu/K) (u)] + [rho*beta*U^2] (darcy-forcheheimer)
and the energy equation is something like this
rho(fluid)*Cp(fluid)[sigma dT/dt + UdT/dx]=k d2T/dx2 + q'" + (mu/K) u^2
k and sigma are:
k= (porosity*kf) + (1- porosity)*ks
Sigma = [porosity(rho*cp)fluid+(1-porosity)*(rho)solid]/(rho*cp)f
for my case there is no heat generation and also I ignored the last term which shows viscous dissipation.
omitting Q"' and (mu/K) u^2, we have :
dividing both sides of equation to rho(fluid)*Cp(fluid) we have:
[sigma dT/dt + UdT/dx]=alpha d2T/dx2
alpha= k / rho(fluid)*Cp(fluid)
I have all the properties of solid and fluid and porosity,so I can easily define alpha,sigma.I wrote my TEqn.H file like this
// Solve the Energy equation
fvScalarMatrix TEqn
fvm::ddt(T)
+ fvm::div(phi, T)
- fvm::laplacian(alpha, T)
TEqn.solve();
I modified createFields.H file either.I defined alpha and sigma in transportProperties file and ask the code to read them from there.
Info<< "Reading transportProperties\n" << endl;
IOdictionary transportProperties
IOobject
"transportProperties",
runTime.constant(),
mesh,
IOobject::MUST_READ_IF_MODIFIED,
IOobject::NO_WRITE
dimensionedScalar sigma
transportProperties.lookup("sigma")
dimensionedScalar alpha
transportProperties.lookup("alpha")
Info<< "Reading field T\n" << endl;
volScalarField T
IOobject
"T",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
Info<< "Reading field p\n" << endl;
volScalarField p
IOobject
"p",
runTime.timeName(),
mesh,
mesh
Info<< "Reading field U\n" << endl;
volVectorField U
IOobject
"U",
runTime.timeName(),
mesh,
mesh
#include "createPhi.H"
label pRefCell = 0;
scalar pRefValue = 0.0;
setRefCell(p, mesh.solutionDict().subDict("SIMPLE"), pRefCell, pRefValue);
singlePhaseTransportModel laminarTransport(U, phi);
autoPtr<incompressible::RASModel> turbulence
incompressible::RASModel::New(U, phi, laminarTransport)
and finally my code is something like this,I used include TEqn.H out of simple loop.
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration |
\\ / A nd | Copyright (C) 2011-2013 OpenFOAM Foundation
\\/ M anipulation |
License
This file is part of OpenFOAM.
OpenFOAM is free software: you can redistribute it and/or modify it
under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License
for more details.
You should have received a copy of the GNU General Public License
along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>.
Application
porousSimpleFoam
Description
Steady-state solver for incompressible, turbulent flow with
implicit or explicit porosity treatment and support for multiple reference
frames (MRF)
#include "fvCFD.H"
#include "singlePhaseTransportModel.H"
#include "RASModel.H"
#include "simpleControl.H"
#include "IOMRFZoneList.H"
#include "IOporosityModelList.H"
#include "fvIOoptionList.H"
int main(int argc, char *argv[])
#include "setRootCase.H"
#include "createTime.H"
#include "createMesh.H"
simpleControl simple(mesh);
#include "createFields.H"
#include "createFvOptions.H"
#include "createZones.H"
#include "initContinuityErrs.H"
Info<< "\nStarting time loop\n" << endl;
while (simple.loop())
Info<< "Time = " << runTime.timeName() << nl << endl;
// Pressure-velocity SIMPLE corrector
#include "UEqn.H"
#include "pEqn.H"
turbulence->correct();
#include "TEqn.H"
runTime.write();
Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
<< " ClockTime = " << runTime.elapsedClockTime() << " s"
<< nl << endl;
Info<< "End\n" << endl;
return 0;
I defined fvscheme and fvsolution file for T equation but I did not understand why this code give me wrong data.
would you please help me in this case,I'm really confused :(
every suggestion would be greatly appreciated.
if anyone has an experienced in this case please send me his/her email.
best regards
Mohsen
m5m5kh September 4, 2013 10:46
error after run
this error happened after running the code
Time = 0.014
GAMG: Solving for p, Initial residual = 0.964789, Final residual = 0.0417207, No Iterations 17
time step continuity errors : sum local = 2.99708e+12, global = 2.90211e+11, cumulative = 2.90211e+11
DILUPBiCG: Solving for T, Initial residual = 0.994907, Final residual = 0.0487249, No Iterations 22
ExecutionTime = 5.1 s ClockTime = 5 s
Time = 0.015
#0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 at tensorField.C:0
in "/home/vaio/OpenFOAM/vaio-2.2.0/platforms/linux64GccDPOpt/bin/newPorousSimpleFoam"
#6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception (core dumped)
vaio@vaio-SVE14122CVW:~/OpenFOAM/vaio-2.2.0/run/m$
