sequential injection stimulation using the multiphaseInterFoam |
September 6, 2013, 09:17 |
salame ama
Rep Power: 13 |
Hi, Formers:
these days, i used the multiphaseInterFoam solver for stimulating the sequential injection. but the results not OK. i think the problems emerge in the alpha setting. I want to stimulate first inject O(fluid) in the cavity, some time later, stop O and inject the M (another fluid) with the same inlet. Relevant files below: First, inject O....... 1 alphaair dimensions [0 0 0 0 0 0 0]; internalField uniform 1; boundaryField { inlet { type zeroGradient; } outlet { type inletOutlet; inletValue uniform 1; value uniform 1; } down { type symmetryPlane; } wall { type zeroGradient; } frontAndBack { type empty; } } 2 alphaM dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } outlet { type zeroGradient; } down { type symmetryPlane; } wall { type zeroGradient; } frontAndBack { type empty; } } 3 alphaO dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type fixedValue; value uniform 1; } outlet { type zeroGradient; } down { type symmetryPlane; } wall { type zeroGradient; } frontAndBack { type empty; } } 4 setFields efaultFieldValues ( volScalarFieldValue alphaair 1 volScalarFieldValue alphaO 0 volScalarFieldValue alphaM 0 ); regions ( boxToCell { box (-0.01 -0.01 0.001) (0.001 0.002 0.003); fieldValues ( volScalarFieldValue alphaO 1 volScalarFieldValue alphaM 0 volScalarFieldValue alphaair 0 ); } Second, after injecion 0.6s, stop O and inject M, I change the alphaO and alphaM in the 0.6 result file without changing others. like: alphaM: dimensions [0 0 0 0 0 0 0]; internalField nonuniform List<scalar> 3620 ( -1.34342e-09 -1.3543e-09 ............... ) ; boundaryField { inlet { type fixedValue; value uniform 1; } outlet { type zeroGradient; } down { type symmetryPlane; } wall { type zeroGradient; } frontAndBack { type empty; } } alphaO: dimensions [0 0 0 0 0 0 0]; internalField nonuniform List<scalar> 3620 ( -3.24112e-10 -3.36625e-10 ..................... ) ; boundaryField { inlet { type zeroGradient; } outlet { type zeroGradient; } down { type symmetryPlane; } wall { type zeroGradient; } frontAndBack { type empty; } } the result is (writeInterval 0.2s): 1. 0~0.8s, have no change in the alpha (O, M, air) http://xiangce.baidu.com/picture/det...dfef5441cc5425 2, from 1s, the alpha changed 1s:http://xiangce.baidu.com/picture/det...6a113f59070475 1.2s:http://xiangce.baidu.com/picture/det...68e8d92babf075 So, can u kindly help me solve the problem? |
September 11, 2013, 09:38 |
salame ama
Rep Power: 13 |
the pictures
1. 2. 3. Hi, Formers: these days, i used the multiphaseInterFoam solver for stimulating the sequential injection. but the results not OK. i think the problems emerge in the alpha setting. I want to stimulate first inject O(fluid) in the cavity, some time later, stop O and inject the M (another fluid) with the same inlet. Relevant files below: First, inject O....... 1 alphaair dimensions [0 0 0 0 0 0 0]; internalField uniform 1; boundaryField { inlet { type zeroGradient; } outlet { type inletOutlet; inletValue uniform 1; value uniform 1; } down { type symmetryPlane; } wall { type zeroGradient; } frontAndBack { type empty; } } 2 alphaM dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } outlet { type zeroGradient; } down { type symmetryPlane; } wall { type zeroGradient; } frontAndBack { type empty; } } 3 alphaO dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type fixedValue; value uniform 1; } outlet { type zeroGradient; } down { type symmetryPlane; } wall { type zeroGradient; } frontAndBack { type empty; } } 4 setFields efaultFieldValues ( volScalarFieldValue alphaair 1 volScalarFieldValue alphaO 0 volScalarFieldValue alphaM 0 ); regions ( boxToCell { box (-0.01 -0.01 0.001) (0.001 0.002 0.003); fieldValues ( volScalarFieldValue alphaO 1 volScalarFieldValue alphaM 0 volScalarFieldValue alphaair 0 ); } Second, after injecion 0.6s, stop O and inject M, I change the alphaO and alphaM in the 0.6 result file without changing others. like: alphaM: dimensions [0 0 0 0 0 0 0]; internalField nonuniform List<scalar> 3620 ( -1.34342e-09 -1.3543e-09 ............... ) ; boundaryField { inlet { type fixedValue; value uniform 1; } outlet { type zeroGradient; } down { type symmetryPlane; } wall { type zeroGradient; } frontAndBack { type empty; } } alphaO: dimensions [0 0 0 0 0 0 0]; internalField nonuniform List<scalar> 3620 ( -3.24112e-10 -3.36625e-10 ..................... ) ; boundaryField { inlet { type zeroGradient; } outlet { type zeroGradient; } down { type symmetryPlane; } wall { type zeroGradient; } frontAndBack { type empty; } } the result is (writeInterval 0.2s): 1. 0~0.8s, have no change in the alpha (O, M, air) http://xiangce.baidu.com/picture/det...dfef5441cc5425 2, from 1s, the alpha changed 1s:http://xiangce.baidu.com/picture/det...6a113f59070475 1.2s:http://xiangce.baidu.com/picture/det...68e8d92babf075 So, can u kindly help me solve the problem?[/QUOTE] |
Display Modes | |
Diesel injection problem | Jurek | FLUENT | 2 | June 16, 2017 07:05 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 02:30 |
jou file command for the injection! | asal | FLUENT | 0 | June 4, 2013 05:15 |
On DPM injection properties. | akr | FLUENT | 4 | October 23, 2006 11:54 |
using injection file and parallel process | Cindy Jones | FLUENT | 0 | January 23, 2003 13:40 |
