WIKI MRFSimpleFoam Tutorial
Old   September 13, 2013, 05:19
Default WIKI MRFSimpleFoam Tutorial
DANG QUOC BAO
baoaero is on a distinguished road
Dear Foamers,
Currently, I run solver MRFSimplefoam from Wiki tutorial. I set initial boundary conditions and follow the instructions in the tutorial. When I run this tutorial with angular velocity 10 rad/s, it comes to a very good result. However, in case of 15, 20 rad/s, errors occur (core dump). I'm not very clear with these circumtances, could you clarify it for me? Thank you very much for your supports. Please download file (case) from link:
https://www.dropbox.com/s/rapwmmfb60..._khoivuong.zip
Looking forward to receiving your ideas.
Thanks you very much...
baoaero is offline   Reply With Quote
Old   September 16, 2013, 10:09
Frank Ubber
kornickel is on a distinguished road
Did you try lowering the relaxation factors? You can also try to use upwind schemes in your epsilon and k divSchemes and linearUpwind grad(U) in your div(phi,U)
kornickel is offline   Reply With Quote
Old   September 17, 2013, 21:05
DANG QUOC BAO
Dear kornickel,
Thanks for your advice, I've carried out following your instructions and have good results.
Now I am doing some case studies using solver MRFSimpleFoam and SRFSimpleFoam to simulation flow over rotating flat. Parameter of flat includes length= 200 mm and width=20 mm with velocity inlet 10m/s. I used Turbulence property tools on website www.cfd-online.com for calculating initial boundary conditions of epsilon, k, omega...In case MRFSimpleFoam, I generated mesh model of flat which includes 3 zones fluid_inside (rotate), fluid_outside (stator), balde. However, both of the cases do not converge, bounding k and results of pressure and velocity very large. I dont know the reason why the errors appears.
I attached 2 cases (the following links) for MRFsimple and SRFSimple, could you have a look and help me identify where the problem is (due to initial boundary conditions, quality of mesh, fvchemes, fvsolution,...). I am confused but don't know where to find the answer for this problem.
https://www.dropbox.com/s/ks016s1eyx...am_plat.tar.gz
https://www.dropbox.com/s/etozypdxdz...am_plat.tar.gz
Thanks for your help.
Bao Dang
MRFSimpleFoam Tutorial bastil OpenFOAM Running, Solving & CFD 48 August 1, 2012 10:00
Error From MRFSimpleFoam (wiki) Fonong OpenFOAM 0 September 10, 2011 12:09
Difference between OF1.5x and OF1.5-dev for the MRFSimpleFoam tutorial mai OpenFOAM 0 November 15, 2009 17:09
Wiki copyrights and licenses Jonas Larsson CFD-Wiki 15 October 3, 2005 17:23
CFD Wiki - We Need More Help! Jonas Larsson Main CFD Forum 0 September 26, 2005 08:11
