What is phi in simpleFoam
Like Tree17Likes
  • 10 Post By gschaider
  • 2 Post By chegdan
  • 1 Post By armyou
  • 3 Post By wyldckat
  • 1 Post By armyou
Old   October 21, 2008, 23:39
Default What is phi in simpleFoam
ehsan vaghefi
ehsan_vaghefi is on a distinguished road
Hi there
I have been using simpleFoam to solve my problem, I was wondering the what is the "phi" file that openFoam is calculating ?
a more general question , can calculate fluxes (as vectors) on each of nodes ?
Cheers. Ehsan
ehsan_vaghefi is offline   Reply With Quote
Old   October 22, 2008, 07:14
Default As this phi question creeps up
Assistant Moderator
Bernhard Gschaider
As this phi question creeps up every 2 weeks or so, I thought it might be a good candidate for the FAQ: http://openfoamwiki.net/index.php/Main_FAQ#What_is_the_field_phi_that_the_solver _is_writing
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   September 7, 2011, 11:31
Default phi Field in Momentum and Eenrgy Equations
hawkeye321 is an unknown quantity at this point
Hi Everybody
I have added temperature equation to icoFoam in the manner that has been described in
http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
The main part is
fvScalarMatrix TEqn ( fvm::ddt(T) + fvm::div(phi, T) - fvm::laplacian(DT, T) );From a mathematical manipulation i founded out that phi
should be "ui + vj" here. And this vector form for phi is in complete disagreement with what has been described for the field phi in the following page
"http://openfoamwiki.net/index.php/Main_FAQ"
in section "3.1.3 What is the field phi that the solver is writing"
"3.1.3 What is the field phi that the solver is writing "
The answer in this file is
the mass flow through the cell faces ( with the area of the face).
In Summary: Do you guys know whether phi is different in the vector form of the momentum equation and scalar temperature equation! What I had founded out is that YES, it should be different. But I am NOT sure!
I would appreciate if someone helps me!!
hawkeye321 is offline   Reply With Quote
Old   September 7, 2011, 18:25
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Originally Posted by mahdiiowa View Post
Hi Everybody
The main part is
phi is actually a surfaceScalarField, which is different than the vector field. Phi is either interpolated from U (see $FOAM_SRC/finiteVolume/cfdTools/incompressible/createPhi.H) or is directly calculated in your PISO algorithm and then used in your energy equation if you just added it to icoFoam. so its not exactly the same as your U but is correctly used in your Teqn. Hope that helps.
Dan
Kummi and lpz456 like this.
chegdan is offline   Reply With Quote
Old   July 22, 2013, 11:10
Default The units do not seem to match
Sri
srivatta is on a distinguished road
Is Phi just U dotted on to A or rhoU dotted on to A as you have described on the page. The table has units cu.m/s which would fit the first description of Phi (U dotted on to A).
Thanks,
Sri
srivatta is offline   Reply With Quote
Old   September 28, 2013, 02:21
eric
armyou is on a distinguished road
I just start learning FOAM and also have the same question about phi.
In the equation of motion UEqn, phi seems to be rho*U.
But in the equation of energy TEqn, phi is U. This phi bothers me a lot. Can anyone explain it please. Thanks in advance.
lpz456 likes this.
armyou is offline   Reply With Quote
Old   September 29, 2013, 06:37
Retired Super Moderator
Bruno Santos
Greetings to all!
openfoamwiki.net is undergoing some changes on the FAQ section. I've updated the FAQ associated to this thread's topic: http://openfoamwiki.net/index.php/FA..._is_writing.3F
@Eric: You didn't mention which solver you were looking at, but the answer should be simple: compressible solvers use the rho field; incompressible solvers do not use the rho field.
If look at the user guide, section "2.1.1.3 Physical properties", you'll see that the fluid density is implied when using "kinematic viscosity nu": http://www.openfoam.org/docs/user/cavity.php
Best regards,
Bruno
PS: I also merged the two threads where Eric had posted, because it made sense to keep the two threads in a single discussion.
EleCr, rafa13 and vishal0 like this.
Old   September 29, 2013, 11:00
eric
Thank you very much for the explanation. I am now much clearer with this little guy phi.
rafa13 likes this.
SimpleFoam nutilda an R linnemann OpenFOAM Running, Solving & CFD 13 October 9, 2014 08:14
Problems with the RSM in simpleFoam sberg OpenFOAM Running, Solving & CFD 10 February 25, 2014 19:39
NACA0012 with simpleFOAM nuovodna OpenFOAM Running, Solving & CFD 7 May 19, 2010 04:58
Using simpleFoam with water nico765 OpenFOAM Running, Solving & CFD 7 October 23, 2007 05:39
SimpleFoam woes msrinath80 OpenFOAM Bugs 2 April 13, 2007 10:15
