September 23, 2013, 05:30 |
Interfoam - sump pump modelling
I'm trying to model a water sump using Interfoam. Attached is the link to my model:
https://www.dropbox.com/sh/9bhhbvj5n1yhov1/tboAYJyAg_ I've got the model to run until about 0.8 or 1.6s before crashing. I think it occurs when the water plunges down to the sump. The model can also run without utilizing setfields, in most situations. Can anyone please help check whether my boundary conditions are alright? I've tried numerous iterations, but have so far got a viable solution. Thanks! |
September 23, 2013, 12:46 |
Tobias Holzmann
Rep Power: 51 |
1. polyMesh/boundary Code:
inlet, outlet, atmosphere = patch not wall Code:
U_outlet why fixed? alpha_outlet outlet inlet value = 1? . . . Regards Tobi |
September 24, 2013, 01:42 |
Hi Tobi,
Thanks! Model is running fine! |
September 24, 2013, 20:58 |
alpha 1:
outlet : inletoutlet 0 p_rgh: fixedFluxPressure uniform 0 for all except inlet U outlet is specified because I'm trying to model a pump. Do you have any suggestions? |
September 25, 2013, 00:55 |
Franz Jacobsen
Hi
you could try FlowRateInletVelocity I noticed that the level of refinement around pump inlet is probably too course to model swirl cheers Franz |
September 25, 2013, 01:01 |
Hi Franz!
Thanks! Yup I'm running a model with a refined mesh. Any way to make it solve faster? |
September 25, 2013, 01:19 |
Franz Jacobsen
you can eliminate the upstream channels, I don't think it's necessary for what u want to do
September 25, 2013, 01:27 |
ok i'll try that too.
One more thing, I've tried the different filters (contour, threshold, smoothing, etc.) to capture the free surface vortex, but so far no luck. http://www.youtube.com/watch?v=bR3rulCQS08 was the video you posted post-processed by Paraview or Blender? How many cells were you using too? Thanks! |
September 25, 2013, 02:45 |
Franz Jacobsen
that video was created with paraview while this one;
http://www.youtube.com/watch?v=oqtNdocCaJo was created using blender, and has about 1M cells. Glad someone has watched the videos :-) |
September 25, 2013, 03:19 |
#11 |
Those videos are exactly what I want Any tips on how to do it on paraview, if not blender?
September 28, 2013, 00:03 |
#12 |
Franz Jacobsen
Hi, excuse my late reply, I ran your model with some modifications, as mentioned above. The outlet is sucking in air, as shown in the attachment . Vortices would probably be obscured by the disturbance caused by the cascade. This common type of wet well pump station would typically feature additional physical elements in the arrangement, to mitigate these undesirable flow characteristics.
The videos from paraview are created by pressing "Save Animation" in the file menu. cheers Franz |
September 28, 2013, 02:37 |
#13 |
Hi Franz,
Thanks for taking the time to run the model. Speaking of which, how long did you took? And what was your setup (mesh size, and computer specs?) Also, did you used 'contours' filter to produce the left side picture? perhaps with 'smoothing'? or is it 'threshold'? And for the import in blender, was it done in x3d? and I have to individually import each time steps? Appreciate the help! |
September 29, 2013, 05:28 |
#14 |
Franz Jacobsen
I used the Helyx-OS GUI for setting up the model and running it, as well as playing around with mesh settings. It did not take long.
I had to make some assumptions regarding flow rate that would result in vortices, using engineering formula. The water surface is produced using the contours filter, give it a try. You can also import to blender using scripting. The model is still too basic for accurate assessment but adequate to show qualitatively that this pump station layout would contribute to pump failure in a short time. |
September 29, 2013, 21:22 |
#16 | |
Thanks for the information. I'm running a case with about 1.5 million cells, parallel with 2 cores. Still taking me at least a day to develop a closed loop system. By close loop, I mean the water reaching the 'plunging' stage and at the same time being pumped out. I've set the 2 CFL conditions to 1.0 and 0.5. I understand that to create the vortices the initial levels of the water should not be too high from the bellmouth, and the suction from the pumps have to be strong enough to create them. Am I missing anything? I've been able to create similar illustrations using 'contour' filter, but I am also interested in the blender scripting too, if you are willing to share. Thanks! |
June 20, 2014, 02:07 |
#17 |
Zhao Bing
Rep Power: 12 |
Hi cfdan,
I am working on similar problem, but still having some trouble with BCs. Would you mind to share a working copy of your model. The dropbox files seem have been removed. Thanks! |
October 12, 2021, 12:04 |
#18 |
Munaf
Rep Power: 6 |
Hi Cfdan
I am doing a similar to the sump pump model you did and am facing issues most probably with my boundary conditions i am wondering if it is possible to share the case file please as am struggling for some time many thanks |
interfoam, sump, water |
Blood Damage Modelling via Particle Tracking in a Centrifugal Heart Pump | scatman | CFX | 7 | January 8, 2018 00:59 |
Low temperatures modelling heat pump with source terms | stahl | FLUENT | 0 | November 26, 2010 16:43 |
pump meshing inside the sump | ashwin | FLUENT | 0 | March 16, 2007 06:57 |
Pump in a sump meshing | Ashwin C Punjabi | FLUENT | 0 | March 12, 2007 23:52 |
jet pump modelling | mathews | FLUENT | 0 | January 31, 2007 05:29 |
