Is there a tool to reset case or delete the timestep folders of previous running?
Old   September 23, 2013, 07:35
Default Is there a tool to reset case or delete the timestep folders of previous running?
Lü Yi
funature is on a distinguished road
hello everyone,
I want to run a case several times with different boundary conditions, the BC dictionaries are changed programmaticlly. And I need a tool to reset the case before each running so that I can get the last timestep correctly. Is there such a tool to help clean up the folder?
regards
Yi
funature is offline   Reply With Quote
Old   September 23, 2013, 07:37
Bernhard
Bernhard is on a distinguished road
pyFoamClearCase.py might help you: http://openfoamwiki.net/index.php/Contrib_PyFoam
Bernhard is offline   Reply With Quote
Old   September 23, 2013, 07:51
Lü Yi
Bernhard, thanks! It seems to be the right tool for me, but unfortuntly I cannot use PyFoam. Is there no such tool inside OpenFoam?
Old   September 23, 2013, 07:54
Bernhard
You just have to install PyFoam first, you can do that in your own folders.
Alternatively, you can look in $WM_PROJECT_DIR/bin/tools/CleanFunctions where you find some bash functions using the same thing. However, I like pyFoam a bit better.
Old   September 23, 2013, 08:17
Lü Yi
Sorry, I forgot to mention that I use OpenFoam under Windows because of certain reason. I do think the things will be easier if I can do it under Linux. I'll try PyFoam later.
About the second method, I'm not quite sure how I can use it. I'm using the windows port by symscape. I copied the Allclean file from a tutorial case, but it didn't work, I think I must change something properly for windows even the CleanFunctions work. I tried to google some information about the bash function but without success, maybe you can give me some advice.
Old   September 23, 2013, 08:24
Bernhard
For Windows, I have no clue.
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 09:38
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
How to save a case running in background us FLUENT 0 July 6, 2005 10:43
