October 1, 2013, 08:50 |
interPhaseChangeFoam
vishal
Rep Power: 13 |
I am trying to simulate jet in a different density medium, which gets vaporized once it reaches the vaporization temperature/pressure. Is interPhaseChangeFoam correct solver to deal with this kind of problem???
Please help |
October 1, 2013, 09:09 |
Nima Samkhaniani
Rep Power: 24 |
why not, it seems possible
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
October 3, 2013, 00:25 |
vishal
Rep Power: 13 |
Thanks Nima, I was wondering whether interMixingFoam will be suitable or not as it deal with three fluids,two of which are miscible. But I am not sure whether it will take into account the vaporization of the jet in a different density medium.DO you have any idea??
October 3, 2013, 02:26 |
Nima Samkhaniani
Rep Power: 24 |
as much as i know, it does not consider vaporization
October 3, 2013, 02:35 |
vishal
Rep Power: 13 |
But do you think, that interPhaseChangeFoam takes into account three fluids (water, air and vapour)?? and If i incorporate temperature field into interMixingFoam, can it solve the problem or can I add another phase in interPhaseChange Foam. I think the later one is not possible but do you think incorporating temperature will solve the problem for the former (interMixing Foam)??
October 3, 2013, 09:27 |
NaiXian Leslie Lu
Rep Power: 16 |
Vishal,
If you have a look in interPhaseChangeFoam, you see phaseChangeTwoPhaseMixtures, so it's only two phases. If you want a third phase you can add it yourself. I did it some time ago to take into account the non-condensable gas in a cavitating flow, in the end it was not very successful due to the incompressible methodology. Cheers,
Cheers, Leslie LU |
October 4, 2013, 03:47 |
vishal
Rep Power: 13 |
Which one is easier? 1) adding phase change and temperature model to interMixingFoam or 2) adding a third phase to interPhaseChange Foam???
Any idea, any one ...please reply!! |
October 4, 2013, 05:28 |
Olivier
Rep Power: 17 |
hello,
You should not add a third phase in interPhaseChange to take into account vapour, because this is a VOF solver (thus non miscible phase). => you will have non miscible vapor and air. but you may try to add a transport scalar to the 2nd phase (air) to take into account vapor. However your scalar should not diffuse inside water, so this will not be easy. For this, take a look at this: http://www.cfd-online.com/Forums/ope...tml#post397654 regards, olivier |
interphasechangefoam, vaporization |
interPhaseChangeFoam with nOuterCorrectors != 1 | akidess | OpenFOAM Bugs | 25 | March 6, 2016 09:54 |
Implementation of Temperature Eqn in InterPhaseChangeFoam | Jibran | OpenFOAM Running, Solving & CFD | 14 | June 17, 2015 10:47 |
Wrong forces on a 2D airfoil using interPhaseChangeFoam | Artur | OpenFOAM | 0 | August 7, 2013 11:38 |
Bug about MULES::implicitSolve for interPhaseChangeFoam in OF-1.6 | chiven | OpenFOAM Bugs | 18 | April 18, 2013 22:56 |
A question about UEqn.H (interPhaseChangeFoam) | Zheng.Zhi | OpenFOAM | 3 | April 8, 2013 07:34 |
