simpleFoam, Solving Pressure problem
Old   October 13, 2013, 21:40
Angry simpleFoam, Solving Pressure problem
James
jamescraigie29 is on a distinguished road
Hi All,
Im currently running a case using simpleFoam to analyse the flow over a helicopter fuselage.
There seems to be an issue when solving for pressure.
For example the initial residual =1 but the final residual also =1. Clearly there is something wrong and it takes a VERY long time to solve.
I have mainly used only simpleFoam and havent had this kind of issue before. Does anyone know what could be causing this? Could be something very simple?
Any advice would be appreciated.
Regards,
James.
jamescraigie29 is offline   Reply With Quote
Old   October 14, 2013, 04:05
Artem Shaklein
ARTem is on a distinguished road
Hello, James.
Can you give more details about your case (i.e. boundary conditions)?
ARTem is offline   Reply With Quote
Old   October 15, 2013, 07:42
Default ParaView window
ok
Maimouna is on a distinguished road
Dear,
I have one question about paraView window 3.12.0. It is working properly, but the Apply icon is not activated?
Whats the problem?
What shall I do to activate it?
Best regards
Maimouna
Maimouna is offline   Reply With Quote
Old   October 15, 2013, 07:55
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
James, that sounds like your pressure equation doesn't converge and takes the maximum number of iterations ("maxIter" in fvSolution) to try ("VERY long time to solve."). Did you change something in your fvSolution file?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
openfoam, pressure, simplefoam, solve
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 08:30
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
pisoFoam - unstable pressure residual Industrial_CFD OpenFOAM Running, Solving & CFD 21 February 24, 2013 15:39
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
