October 13, 2013, 14:09 |
boundary condition porblem..
#1 | |
izna O'connor
Rep Power: 12 |
HI Julienn
thanks for taking the time and check my case.. for starters i had already try with symmetryPlane and below was my error Quote:
I hope you be able to help... |
October 13, 2013, 20:47 |
I had a look at your case and tried to run a few sims.
My take is that the mesh is probably the root of the issue. I tried to take things away: - turn turbulence off; - use upwind scheme; - reduce residuals; - use a potentialFoam solution; - change the outlet boundary conditions; - tighten solver residuals. The following picture shows the non-physical spike of velocity after as little as 10 iterations. Sorry, but I can't help further.
--- Julien de Charentenay |
October 13, 2013, 20:52 |
izna O'connor
Rep Power: 12 |
hello Julien..
First of ALl thanks a lot for the useful and intelligent pointers you gave to me.. As wih simpleFoam its not working at all.. I have used pisoFOam and still it not work. But with pisoFoam i include the boundary cond of symmetryPlane.. so lo and behold... the FLow is being as i wanted!!! Thanks heapsssss..... But with pisoFoam, it takes along timeeeee to finish iterating and acheive convergence.. i am now at 20319 second and its sill going strong in iteration.. But at least its giving the required results.. |
October 14, 2013, 02:31 |
Following your post: you may want to try changing:
nNonOrthogonalCorrectors 0; Code:
nNonOrthogonalCorrectors 5;
October 14, 2013, 02:33 |
izna O'connor
Rep Power: 12 |
thanks am trying it right away..
I am obtaining superb resutls with pisofoam. but WHY DOES IT TAKE SOO MUCH TIME TO ITERATE??? |
Display Modes | |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 06:57 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
Setting outlet Pressure boundary condition using CAFFA code | Mukund Pondkule | Main CFD Forum | 0 | March 16, 2011 04:23 |
